Subject: Re: 22.5º miter knives on 1" thick material?
6/13/16
Chris Gray
Website: chrisgrayfurniture.com
We are looking for a lock miter knife or router bit that can do 22.5º joint on 1-1/32" thick material? everything I see online is max 7/8". any body know where I can buy one? Thanks
6/13/16       #2: 22.5º miter knives on 1" thick ...
Edi Silva  Member
Website: silvawoodworking.com
Get a knife made
Edi
6/14/16       #3: 22.5º miter knives on 1" thick ...
Chuck Rankin
Hi Chris:
Here is a link with an insert variable angle shaper cutter that would handle the width you have. The StarkTH17 would do about 1-1/2" thick material with a 22.5 degree angle.
regards,
Chuck Rankin
Wood Tech Enterprises, Inc.
Our website: www.woodtechtooling.com
P.O. Box 2226
Fairview, NC 28730 USA
1-800-TOOLING (866-5464)
Phone: 828-628-4414
Fax: 828-628-4490
View larger image
Stark TH17 Vari Angle Heads
6/15/16       #4: 22.5º miter knives on 1" thick ...
Chuck, are you saying he can put lockmiter inserts in the variable angle head? He is asking for lock miter!
Even if he can have knives made, assembling (clamping) might be a trick.
6/15/16       #5: 22.5º miter knives on 1" thick ...
Chris Gray
You can find dozens of 1/2" shank router bits, that will allow a 22.5deg. "lock miter" on material thats 7/8" or thinner. Nothing 1"+ ?
Edi- you think we could get a knife custom grind to match up well? It's a male and female set, unlike the 45deg. lock miters.
seems like a lot to ask from a custom ground knife. Where to you get your knifes made?
6/15/16       #6: 22.5º miter knives on 1" thick ...
Edi Silva  Member
Hello Chris
Yes, they can make a custom set for you, I get my custom tooling from Connecticut Saw & Tool.
