Subject: Re: Tension rod for cabinets
6/15/16
Peter Rawlings
I may be looking for a needle in a haystack but I swear I've seen these somewhere, but Google and phone calls got zilch. I may be searching with wrong terms.
What I'd like to find is some small diameter rod that would span the distance between cabinet sides, and fit into 5mm shelf pin holes. Perhaps spring loaded or cam tighten at varying lengths.
Think mini shower or curtain rod that could be moved up and down shelf pin hole line.
I hope that makes sense. Anyone have a line on something like that?
6/16/16       #2: Tension rod for cabinets ...
D Brown
Why not use what is called a spring tension
curtain rod , they come in various lengths and diameters . You may need to adapt the end pins to fit your 5mm holes or use different size holes to fit the rod you find.
6/16/16       #3: Tension rod for cabinets ...
Peter Rawlings
Thanks D, I did think of that but the sticker is adapting to 5mm hole, which I can't modify.
I could use oval closet rod, but would prefer something less bulky and adjustable in length.
6/16/16       #4: Tension rod for cabinets ...
D Brown
Peter , maybe you could affix 5mm
shelf clips to the ends of the spring rods ?
Usually there are plastic or rubber end caps but the rod is steel , it could easily be done get out the JB Weld .
6/17/16       #5: Tension rod for cabinets ...
NBrad
Here is an idea...
Glue one of the CLOSED versions of these onto each end...
http://www.wwhardware.com/us-futaba-rod-support-with-5mm-pins-for-1-5-16
-dia-rod
6/17/16       #6: Tension rod for cabinets ...
Dave L
A quick search turned up 7/16" tension curtain rod. Replace the rubber end caps with 3/8" or 10mm wood dowels (the tube ID should be close to that) that have 5mm pins sticking out the end. I'd turn down 5/8" aluminum and press fit 5mm pins.
6/18/16       #7: Tension rod for cabinets ...
Chris
What is this being used for? I don't understand the purpose.
