Subject: Re: Beaded Inset Door Thickness & Non-Mortise Hinges
6/26/16
Ron Member
Working on a kitchen with beaded inset doors and drawers. After picking up rough and milling 4/4 poplar to 7/8", I'm liking the feel of this thickness.
I didn't want to get into FF and door assembly until I knew if there are non-mortise finial-style hinges that accept 7/8" stock. I was thinking theses:
Hafele Budget Partial Wrap Non-Mortised Decorative Butt Cabinet Hinge with Minaret Finial 71mm (2-13/16'') Height
Will something like this work or do I need to continuing milling this to 3/4"?
Thanks in advance.
http://www.kitchensource.com/hinges/ha-351.86.120.htm?p=HA-351.86.210
6/26/16       #2: Beaded Inset Door Thickness & N ...
Leo G
Because those wrap 7/8" stock won't work unless you feel like making a routing jig to mortise the wrapped section into the door.
I have done this.
6/26/16       #3: Beaded Inset Door Thickness & N ...
Mike Member
I recently used the Horton Brasses hinges they don't wrap so it will work. They are very high quality and if you have a business you can get them at a big discount from the price on the web.
6/27/16       #4: Beaded Inset Door Thickness & N ...
Amerock makes the original non-mortise hinges that look like those Haefele ones. They are typically made for 3/4" doors. I believe they used to make them for 13/16" as well.
