Subject: Re: Thermally treated hardwood
8/6/16
David  Member
Website: dtwoodworker.houzz.com
Do any of you woodwebers have any experience with using heat treated lumber such as Cambia? (http://www.cambiawood.com/) Specifically I want to know if it would fade a lot in color if left unfinished? A little fading is ok. I am not a fan of finishing outdoor furniture as the finish never lasts. If it will keep a semi dark color and not turn silver grey as most woods do outside then it would be a great option. If a finished is used what are you using? Thanks
8/9/16       #2: Thermally treated hardwood ...
Sorry to inform you, unless you oil torrified wood it will fade to grey (as we all do) when exposed to the elements. I have been very happy with spraying a water borne oil finish (Cabot Australian Oil) with a conventional cup gun on wood intended for outdoors. No wiping necessary. The key is to not apply too much finish. Two years on the wood has rich color.
8/15/16       #3: Thermally treated hardwood ...
David Thiessen  Member
Thanks for the info Tom. When you say not too much finish are you doing 1 coat to seal it, then sand and final thin coat or something else?
