Subject: Re: exposed plywood edge
10/14/16
Jim Member
Got a project that calls for laminated cabinets with exposed plywood edges. Also has 2 1/4" floor to ceiling dividers with the same treatment.
Anybody had any experience with this. Plywood seems a lousy substrate for euro cabinets.
Any ideas appreciated.
03_Catering_1.pdf
10/14/16       #2: exposed plywood edge ...
David
Jim, a few thoughts come to mind. Use a PB or MDF core but edge band with a wood that has a very linear grain to it like bamboo or Zebrawood in a pre finished banding that would look similar to what they are wanting. Either of these woods could be presented as exotic upgrades. It would probably require you to make a sample door for them to sell the idea. If the client insists on the plywood then you could use 1" thick baltic birch ply for the doors and fronts. If you could actually glue the laminate to the plywood with pva or urea formaldehyde glue in a press that would be more rigid than contact adhesive and probably more stable. But I would still include a clause in the contract about "no guarantee against warping" with a plywood core. Looking forward to hearing others ideas.
10/14/16       #4: exposed plywood edge ...
Jim Member
I have some samples coming from Rehau.
Something they call multiplex. Anybody ever used that?
Anybody have another source for edgeband that resembles plywood?
10/14/16       #5: exposed plywood edge ...
Bruce H
Wood tape has edgebanding that looks like plywood edges. We have come full circle folks...
10/14/16       #6: exposed plywood edge ...
Alan F.
you could try combo core (classic core) from columbia
10/14/16       #7: exposed plywood edge ...
Chipbored
So glad you asked. We have done both.
Ply as substrate with laminate on top is very expensive as you need to buy quality ply and have laminate pressed front and back. The laminate sheet size we used didn't match up to the ply board size available so much wasted material. You need furniture grade birch. You'll still spend time puttying the edges of the doors and you have to be very careful with your tall doors and panels as they are successively to bowing and twisting.
Using an mdf or chipboard substrate door with melamine already pressed, cut to size edged with the multiplex ply edging is so much cheaper and quicker and looks great. You can still beeswax or danish oil the ply edge for an authentic look.
Multiplex available in .4 and 2mm edging
Also an abs edge tape available in 1mm with ply effect but this looks a lot cheaper and less authentic than multiplex.
Good luck
10/15/16       #8: exposed plywood edge ...
I've seen a few cabinet jobs in trendy restaurants built out of AC ply. The nicest one used MDO ply, which has a decent core and paintable faces.
At the end of the day, they all looked like some guy who owned a restaurant cut up some Homie Dopie ply and slapped it up, then slathered a couple of coats of Minwax poly.
We have built some nice stuff with baltic birch. The good stuff has a consistent decent core.
10/15/16       #9: exposed plywood edge ...
I forgot those timeless OSB cafe cabinets. If the guy remembers to remove that blue stuff all is good.
