Subject: Re: Glass in melamine
Glass in melamine
11/22/16
Richie Alcorn  Member
Website: alcornswoodworking.com
We have a transaction island to do for a commercial client. The back will have a drawer stack in the center with doors on either side. The front will have a blank in the center and needs glass on both sides, ends and tops. My question is, how do we set the glass into the melamine panels and trim them out. I have never used melamine in this situation but it is specified by the customer. Thanks for any ideas.
11/22/16       #2: Glass in melamine ...
Leo G
Surround the glass with an aluminum frame.
11/23/16       #3: Glass in melamine ...
Tom C
I Do not get exactly what you are saying?
This is white Laminated glass 1" in front of white melamine. Glass in CRL alum.extrusions.
Walnut cabinetry behind.
LED strip lighting up in top recess gives a cool effect at night.
Silestone tops-Drop mitered. Silestone Base
View higher quality, full size image (752 X 423)
11/23/16       #4: Glass in melamine ...
I guess what I'm trying to get across is that we need to cut a square or rectangular hole in a sheet of laminate covered particle board and put glass in it. What's the best way to trim this out. The aluminum trim idea is possible but I haven't found a suitable piece to use.
11/24/16       #5: Glass in melamine ...
Derrek
Order panels to size in a RTF door cut for glass. Just cause the customer speced doesnt mean its the best way to do it. This was also cover in an earlier post and somebody was able to cut and band the panel search it as it had good info
11/24/16       #6: Glass in melamine ...
Ed
Hello, I am getting ready to do something similar, planning to rip strips of platforms
( a special undersized plywood with thin crossbands of mdf ) Edgeband inside and rabbit for glass , then mitre corners assemble and laminate inside and outside. I use a veneer press for laminate with titebond glue, hoping to gain some strength from the outer skins.
Have not done this yet , but confident that it will make a good door.
Ed
11/25/16       #7: Glass in melamine ...
BLS Member
When we do this we cut out hole after the panel is laminated. We then use .018 edgebanding that matches and band the inside of the hole. We put the glass in the back side with mirror mounting clips that take a screw to hold them in. It's the quickest and easiest way to do it.
