Subject: Re: Cnc Dowel inserter
Cnc Dowel inserter
12/8/16
Jim K
Looking into a cnc dowel inserter. Just wondering how many of you are using the dowel inserter for face frame parts? Either a 4' or 8' machine.
12/9/16       #2: Cnc Dowel inserter ...
Matt Krig
We use one for our frameless case parts, drawers and a few other items. It could work for frames, but it would be a hassle programming part by part for custom sizes. I suppose it could be done for a stock size cabinet and high volume situation, but then you'll need a separate means of clamping them.
Have you looked into the Razorgauge with optimization/defecting, pocket hole boring, labeling and the scribe lines for marking stile and rail placement?
Can you elaborate on why you want to dowel face frames, or a problem you are looking to solve?
12/9/16       #3: Cnc Dowel inserter ...
Jim K
I was looking at the cnc dowel inserter mainly to increase our assembly method and thought maybe we could utilize the machine for frames. The posting of parts is a valid point so I would stay with our pocket screw method. We do one box as oppose to several on face frames so that would probably force me to a 8' machine.
The cnc inserter is being looked at after IWF in August with the fastenlink and lock dowel method for assembly which could work for face frame and frameless assembly. We are a residential shop so AWI doesn't apply to us in terms of the two methods mentioned. Next step is to run some samples with the fasteners before investing in machine.
Thanks for responding.
12/9/16       #4: Cnc Dowel inserter ...
Stuart
I agree with Matt. The programming would be a mess for face frames. I have seen a special interface for this on a Omal or Biesse even there I was not sold on the speed.
You mention the special fasteners, I saw them at IWF and was intrigued and hope to investigate more next year. Many questions left in my mind though. Programming, costs per fastener, additional cnc time required, strength to name a few. What are your thoughts?
12/9/16       #5: Cnc Dowel inserter ...
We use an Omal with measurement.
We programed the Omal to spread a pattern based on the length of the part it measures. It then uses math and logic we created to decide if an additional dowel is needed at the end of the run or if the standard pattern gets one close enough to the edge.
Our CNC uses the same logic. It is pretty magical. For 98% of the parts, put it against the fence and press the pedal and it bores the correct pattern.
I am sure you could figure out a couple programs to do frames. I am not sure that it is a good idea to do it but it could be done.
12/9/16       #6: Cnc Dowel inserter ...
Jim K
Stuart,
Strength is also my main concern with these fasteners. I ordered a sample kit from fasten link and glued the two parts together. Melamine glue in hole only. Next day it seemed pretty solid. I still see it from the sample as a possible weak point do impact say dropping the cabinet on the job or just installation handling. I need to run a complete cabinet box and go from there. Lock dowel at Atlanta seemed to be a better bite on assembly but full production would require a dedicated borer that would insert the H clip. Don't like that idea at this point not knowing the system. Working with lock dowel now to get me the ucs on 9.0 CV and will try a sample run. I need to get further into the weeds to see if this even a cost effective way for construction method.
Thanks for the response.
12/9/16       #7: Cnc Dowel inserter ...
Bruce H
I think the fastenlink lock dowel could put you on par with Ikea, or something lower, if that was our goal. It is using the integrity of particle board and a key hole slot, maybe faster assembly, not necessarily a better product.
12/9/16       #8: Cnc Dowel inserter ...
Alan F.
We have the pocket screw on our Gannomat, you get repetitive accuracy and parametric placement so we will be listing 3 or 4 castle machines.
We use pocket screws all the time for certain connections.
We also looked at the Omal, that is a nice machine they were demoing with the frame setup.
We basically have the same feature set with the Gannomat and were able to take delivery this year, plus our previous Gannomat is still running and is 16 years old so we have a good history with Tritec.
We also bought inside and out side miter fences for doweling mitered parts.
A-
Gannomat
