Subject: Re: Warping,
Warping,
4/5/17
Joe Member
Or Cupping,
I thought I knew this answer, but have recently got it backwards, and when Googleing for an answer I have been getting both ways. The image of the end grain of a board as seen here, if it were to warp, or cup, with that as the grain pattern, will the top surface be a hill or a valley?
View higher quality, full size image (997 X 403)
4/5/17       #3: Warping, ...
An easy way to remember it is when wood dries the rings try to straighten out.
4/5/17       #4: Warping, ...
Joe Member
So in the example shown the top would be concave or a trough, and NOT a hill
4/5/17       #6: Warping, ...
If it gains moisture it will go the other way.
4/5/17       #7: Warping, ...
Joe Member
Well,
The boards are sanded, and then dipped in a tank of Zinsser Bulls eye Sealcoat sanding sealer. and soaks for about a minute, then pulled out of the tank and set on a rack to let dry.
Then these 15" long by 6" wide and 3/4" thck boards could stay like this for up to 6 months before final use when they get sanded and laquered finished. I rarely have any warp, but when they do it can make the piece un useable if it was the valley way. If it warps at al the Hill can be worked around. but the valley makes it almost firewood. for the stove next winter.
4/5/17       #9: Warping, ...
Buy rift or quarter sawn wood, not flat cut if they need to be more stable.
4/6/17       #10: Warping, ...
TimG
The top will be concave, which is why you should always place heart side up on outdoor decking. Of course, the sap side will always be the better looking side!
4/6/17       #11: Warping, ...
JeffM
The easiest way I think is to imagine that as part of the tree (the top of your pic being the outside of the tree, the bottom being the inner part of the tree) The outside of the tree is always dryer and will dry out faster causing it to be shorter and cup upward. The bottom of your board will retain more moisture and stay longer than the top. So, when that pic of a board dries out you will have an upside down rainbow.
