Subject: Re: Compact laminate or phenolic cabinets
5/9/17
Skillet Member
We have been asked to build a few cabinets out of phenolic material. We are looking at Wilsonart Compact. Anyone had any experience building casework out of this material? What type of fasteners, adhesives, how do you handle finished ends, finishing exposed edges,etc. We do eurostyle typically, with dowels and confirmats but will likely need to modify a few procedures. Don't think my spur bits in my horizontal boring machine will like this material. Looking for any information from anyone who has used this type of product and could illuminate me as to the pitfalls I haven't forseen. I have attached a link to Wilsonarts Fabrication guide. Thanks for any assistance rendered.
Compact fabrication guide.
5/9/17       #2: Compact laminate or phenolic cabine ...
Dave Edgerton  Member
We have used the formica compact laminate. For bonding you will have to use epoxy and I suggest the 3m autobody panel adhesive. It is expensive but it works. No wood dowels. Almost better to use a metal or plastic dowel and epoxy. Confirmats wont work as they dont cut into the compact laminate because it is so hard. You have to rout finish all your end cuts. Get lots of carbide bits.
5/10/17       #3: Compact laminate or phenolic cabine ...
Many companies that specialize in solid phenolic casework regularly for chemistry labs will commonly use 1/2" (13mm) material for the doors to reduce weight. This is also a common practice when fabricating casework using solid surface material like Corian for hospital environments.
This poses a unique challenge for using most European concealed hinges which can have a cup depth anywhere from 11mm to 13mm.
Salice offers the Series 100 hinge which features a cup depth of only 8mm that can easily be installed in 1/2" doors using the phenolic manufacturers recommended fasteners.
The Series 100 is available with opening angles of 105 degree and 155 degree.
5/24/17       #4: Compact laminate or phenolic cabine ...
Skillet
Having done a little research and talking with people familiar with this product, I would like to pass on what I have learned in case anyone comes to this thread looking for information. This material is a different animal and I would not attempt to do this if you are not completely set up for it. There are vendors that do this on a daily basis and will cut parts for you and flat ship them and you can assemble in your shop. This is what I have chosen to do and will work out nicely for this project. I don't want to sound like an advertisement but if someone would like contact information for the suppliers I spoke with you can email me and I will send you that info. The project should be complete by the end of the summer.
