Subject: Re: Short 5mm Pins
Short 5mm Pins
7/3/17
cabmaker
Does anybody know where to get a short version of this 5mm pin?
I can easily find versions that are 1 inch long. What I need is something about 5/8 to 3/4 inch length.
Any suggestions where to look?
View higher quality, full size image (563 X 484)
7/3/17       #2: Short 5mm Pins ...
cabmaker
Forgot to mention does not need the beveled ends. Both ends will be buried into plywood so are not visible.
7/3/17       #3: Short 5mm Pins ...
duster
What is your application? Why metal instead of wood?
7/3/17       #4: Short 5mm Pins ...
cabmaker
Is hard to tell from these pictures but we use the pins for producing adjustable dividers for cookie trays and pyrex drawers.
We drill a pattern similar to shelf holes on 5/8 inch centers, The euro ply dividers have a groove cut into them that doesn't quite make it all the way to the edge. We produce this groove with a fairly small diameter saw blade so that it can relatively deep with as small arc as possible.
The groove is not very deep hence the need for a shorter pin. We may end up having to use a spoon shaped shelf pin.
7/3/17       #5: Short 5mm Pins ...
eddie
Hafele has some 16.5mm long. There is a .5mm thick by 7mm dia. flange in the middle of this pin. Not sure if the flange would cause you problems.
7/4/17       #6: Short 5mm Pins ...
Nick
I use these from Richelieu, I'm sure another supplier (Hafele etc) would have something similar as well.
Nick
Richelieu Shelf Pins
7/4/17       #7: Short 5mm Pins ...
Bob C. Member
Try G.L. Huyett, they carry dowel pins in many different sizes. M5 is a common size, you should be able to find something suitable for your application.
Huyett Dowel-Pins
7/4/17       #8: Short 5mm Pins ...
Eddie
You need this:
https://www.hafele.com/us/en/product/swedish-type-shelf-support-5-mm/0000
006200027f1500010023/;sid=ed2GlPDe1KmGlKmF-pylf_DUI6V3mHQmdCbc7AHSE2LTug==#Search
Parameter=&@QueryTerm=*&Category=vMHAqBtGr5oAAAFJiq5ygnXe&FF.followSe
arch=10000&PageNumber=1&OriginalPageSize=12&PageSize=12&Position=
5&OrigPos=1&PDP=true
7/4/17       #9: Short 5mm Pins ...
Ken Petrunick
Website: http://kpcustomcabinets.com
We just use the pins out of our clear shelf supports
Hafele shelf support with steel-pin
