Subject: Re: Help with new edgebander
8/14/17
Jeff Member
Website: http://wsdesignworks.com
Just bought a Grizzly G0774 Edgebander, same as the Cantek MX330. I know it's far from a high end machine, but so far I'm very impressed by it.
When I'm running anything with atleast a 7-8" long edge it's working great. If I run the short edge of a drawer face, roughly 5", the piece shifts and the edgeband isn't applied.
If I just need to make up larger blanks for drawers, then rip them down, I'm okay with that. I would love any advice on how to get this machine dialed in a bit better.
8/15/17       #2: Help with new edgebander ...
eddie Member
Set the pressure beam down lower. To hold the part tighter. As it is adjusted now. There is not enough pressure to hold it secure.
8/15/17       #3: Help with new edgebander ...
Ed
Most banders have a problem with less than 9 inch long parts, A much wiser cabinet maker told me you can run 5 , but have to hold it square to feed as it runs.
Ed
8/16/17       #4: Help with new edgebander ...
Bruce H
Put a back up block with your part so that the block is about a 1/2 inch behind the edge getting banded. the back up block won't get banded but will help in keeping your part square.
8/17/17       #5: Help with new edgebander ...
Matt M
Do what Bruce said. Run a second piece behind it, but hold it back away from the glue edge.
On the three banders I've used, about 3/4" back was good. That allowed the end trimmers to work properly but gave the narrow piece enough ass to hold the first one well.
