Subject: Re: Great featherboard hold-down
9/12/17
cabmaker
Here is something we use a lot for feather boards and fence hold downs. Is quick to set up and very strong.
View higher quality, full size image (482 X 491)
magswitch
9/12/17       #2: Great featherboard hold-down ...
I recently bought a few of those for featherboards, but was disappointed. The magnet has to be 1,000% parallel to the table to bite at its best, but the mounts for the case are not parallel to the magnetic face. I did some shimming, but even so, the things are not what they should/could be. I was trying to think of some sort of flex mount that would allow the magnet to find its best position. Got distracted....
9/12/17       #3: Great featherboard hold-down ...
cabmaker
I'm surprised by that David.
I have at least a dozen of those magnets in service somewhere in my shop and have not had to pay any particular attention to making sure they are parallel to the work surface.
We use them for stopblocks on the edgesander and featherboards for the table saw. We even use them for alignment blocks on our faceframe easel.
We got our first one as part of a bandsaw fence system from Carter Products.
9/12/17       #4: Great featherboard hold-down ...
I think I need to turn the magnet 'on' and mic the distance from the surface to the mounting flanges, and grind/file until they are all equal per unit.
I am impressed by their power, but their strength is not as strong in side to side as withdrawal. That is, a featherboard situation on a tablesaw may require some back up if the parts are big or if they want to wander off the fence. But withdrawal? that is some incredible power.
You are correct, one can find many uses for these around the shop. I first ran into this type of magnetic base with a dial indicator for machine set-up and checking things. Great for checking saw/spindle runout.
9/12/17       #5: Great featherboard hold-down ...
Why wouldnt you just counter bore the magnet to be a couple thou off the metal surface? We have used the MagSwitch cabinet door latches several times. We do a little modification in that we grind the ears off the mounting screw holes and we just bored them so that the mag latch is flush with the interior face of the door. The mag is not insanely powerful but its plenty strong to hold a door from rattling.
9/13/17       #6: Great featherboard hold-down ...
I do have the magnet protruding out about 1/8", but the face if it is not aligned with the face of the body mounting surface.
That 1/8" makes it so the featherboard is above the table a bit, for chips to escape and for the way we need to hold some parts.
