Subject: Re: disc sander paper source
10/3/17
cabmaker
Does anybody know where to find 8 inch diameter disc sand paper like this?
The hub in center is 3 inch diameter.
10/3/17       #2: disc sander paper source ...
cabmaker
pic
10/4/17       #3: disc sander paper source ...
Hal
Wurth Louis and Co. carries them. 8" dia. 80 grit. 10/bag.
Used them for 9 years edge sanding face frame stiles & rails on the table saw. The shop I worked for didn't have a jointer as the owner had too many operators injure their fingers on it.
8" Edgetech sanding discs
10/5/17       #4: disc sander paper source ...
Did you try Klingspor?
10/5/17       #5: disc sander paper source ...
cabmaker
Well how propitious is this!?!
I have three of these EdgeTech sanding discs. I bought them from Wurth Louis along with a ten pack of 80 grit paper. I don't know why I forgot that. As I recall they only had 80 grit and my guys are asking for finer grit.
Then just yesterday the Klingspor salesman sauntered in during a shop meeting. I told him what I was looking for and he came right up with it.
We have two of these discs set up for dedicated single purpose operations. One of them is used for a plastic laminate gizmo we produce for every kitchen we well. This one only serves to handle the filing operation where two corners of plastic laminate come together. The filing takes only a couple of seconds to accomplish and is always exactly the right amount.
The second disc sander does a similar cut to the corners of rails for bead & quirk kitchens. The amount removed is constant and there is never any blowout at the corner.
View higher quality, full size image (677 X 544)
