Subject: Re: Hinge for flap front over outlet
11/13/17
JeffM
Can someone help out with a concealed hinge that will work for a flap down 5 piece drawer front with 1/4" panel. 1 1/4" rails, so may not be able to bore. Reveal between fronts is only 1/4". 3/4 face frame.
11/13/17       #2: Hinge for flap front over outlet ...
JeffM
It had to be adjustable as well.
11/13/17       #3: Hinge for flap front over outlet ...
D Brown
Why not use a tip out tray hinge the Euro style should be fine.
11/13/17       #4: Hinge for flap front over outlet ...
Andy
By the picture it looks like you got it figured out?
11/13/17       #5: Hinge for flap front over outlet ...
JeffM
tip out tray won't work...Doesn't open far enough unless you're talking one I'm not familiar with...and the pic is just for clarity. The fronts can't be bored unless it's about a 1" diameter. The top and bottom rail is 1 1/4" wide. The other problem is the center panel is 1/4" and inset some in the back.
11/13/17       #6: Hinge for flap front over outlet ...
JeffM
Maybe a mini cup hinge will work...Anyone have experience with them?
11/13/17       #7: Hinge for flap front over outlet ...
Andy
I think the mini cup hinge has a straight arm, might be too deep. You can always fill in (glue and clamp plywood or solid) the back of the drawer front for the hinge bore.
11/13/17       #8: Hinge for flap front over outlet ...
JeffM
Thanks for the help. I initially set the outlet box back to accommodate straight arm hinges, so I'm going to give the minis a shot. Thought about filling in the back but that would only give me about a 3/8" depth with a 1/4" center panel. Probably not enough.
11/13/17       #9: Hinge for flap front over outlet ...
D Brown
Pretty sure the euro style opens more than the reva shelf type.
11/13/17       #10: Hinge for flap front over outlet ...
Peter Rawlings
I just used a set of these. Worked nice, especially after a shot of dry lube. They are proud of them, though.
Hinges
11/14/17       #11: Hinge for flap front over outlet ...
Jeff,
The Salice mini hinge has a 26mm cup bore but will only give you a maximum overlay on the bottom frame rail of 11/16". I believe this to be true for any 26mm cup Euro hinge on the market. Here is a drawing.
If you decide to go this route, the Salice part numbers are:
Hinge: C6A7C99
Plate: B2R3E09/15
Edge bore distance: 6mm
The Pojjo hinge doesn't look like a bad solution.
Best of luck,
Dennis
View higher quality, full size image (736 X 1016)
    Lamello
