Subject: Re: prefinished plywood
prefinished plywood
1/16/18
John B Member
Website: http://woodmanseewoodwrights.com
I currently specialize in mainly face frame style kitchen cabinetry, mostly inset doors but some overlay, and use 3/4" pre-finished maple for the box construction. I have bought from a couple of suppliers that will deliver to our location, but see some fluctuations in quality at times. I prefer Columbia product with an aspen/poplar core but it does run more than some other brands with what appears to be a fir veneer core. I'm interested in what others are using, average pricing, brand/mills, in different parts of the country. Here, it runs from the low to mid $60's per sheet to the mid $80's for a more premium product. Also wondering if anyone has found 3/4" prefinished maple with the mdf veneer layers under face. Seems like it would give a smoother face for the times we are doing solid color finishes on end panels exposed.
1/17/18       #2: prefinished plywood ...
Family Man
John, There is a pretty wide variety of products and brands on the market. The price point if they haven't jumped in your market will. A tariff just removed over half of the prefinished plywood on the market- Chinese and that is causing not only price jumps but shortages.
I have found the classic/armor core type product you are speaking about to be a little flatter, less rippling in face veneer. But usually for the client that isn't too much of an issue, especially since it's inside a box with goods stacked on it. Hard to get a real good visual on it.
1/17/18       #3: prefinished plywood ...
chris
I use Garnica, an all poplar core, 2 extra ply's than typical 3/4. Light weight, flat. White birch and in the low $60 UV1S. I have yet to have a sheet delam or not lay flat for me in the 2 years I've been machining it.
1/18/18       #4: prefinished plywood ...
Pdub
So that Garnica is only UV finished on 1 side and it still lays flat?
1/18/18       #5: prefinished plywood ...
chris
Like all other plys, it comes in UV2, but yes the UV1 lays flat. When I run the next batch on the CNC I'll take a picture. Of course ply isn't MDF or PB, but then again I cut PB all the time that has tension in it and moves. I have never had an issue with Garnica UV1 laying flat on the CNC. I also can count the voids I've seen on one hand. It's a WPF white birch, I personally like the prefinished maple. The WPF birch is kind of bland to me but it is the inside of a cabinet and I'm not worried about the bland part. The other issue I have, and it might only be my supplier but my supplier does not carry it in 1/4". So we started cutting the backs 1/2" with no nailers on the backs.
1/19/18       #6: prefinished plywood ...
Hen Bob Member
I 2nd the Garnica
1/19/18       #7: prefinished plywood ...
We've always used Columbia 3/4" prefinished 1 or 2 sides. Our backs are always 1/2' prefinished 1 side. 16 gauge staples.
I bought a few sheets of the imported stuff about 10 years ago. It was so bad we chopped it up and used it for ladders & kicks.
1/19/18       #8: prefinished plywood ...
John B Member
Chris,
Is this imported from Spain? I'm trying to see if there is a dealer in the NE I could get it from. Atlantic Ply, Richeleiu and Wurth are my closest suppliers.
1/20/18       #9: prefinished plywood ...
chris
It is from Spain, yes. I believe Antlantic ply carries it. They use to be near me. There should be one in ME and MA
1/20/18       #10: prefinished plywood ...
Hen Bob Member
Wurth has it by us.
1/20/18       #12: prefinished plywood ...
Michael Eftink
I tend to use chinese import on the inside of my cabinets...it does vary in thickness and voids, but it is the inside of the cabinets. It runs in the mid 40's per sheet for 3/4" for 1 side finished..add $3 bucks for both sides. I use a higher grade non-import for finished areas on the outside of the cabinet. It will normally run mid $60's for birch or maple.
1/22/18       #13: prefinished plywood ...
Ken Member
We used Columbia for years but have switched to Garnica and been using that for a couple years now. It is about $7-$8 less per sheet and the quality is better. When using Columbia UV1S, we always had a least 2 sheets in a unit that would be scratched badly. I don't think that I have seen one yet in the Garnica. The finish on the Garnica is noticeable smoother and the weight per sheet is less (they claim 30%) which make a big difference for us since we make a lot of really large units that we have to haul up multiple flights of stairs. We buy the Maple UV1S, Maple unfinished, and Maple UV2S.
1/22/18       #14: prefinished plywood ...
Kevin Jenness
I also have had good results with the Garnica line, sourced from Atlantic Plywood. It is not formaldehyde free, if that makes a difference, though it does meet a certain standard (CARB 4?) for emissions.
