Subject: Re: Tightening RTA Fittings
2/11/18
Stu
Anyone had any success tightening Rafix (or similar) cams with screw gun or cordless screwdriver? I've always used a ratcheting screwdriver, but have had some soreness lately as a result.
2/11/18       #2: Tightening RTA Fittings ...
If I was going to try that I would use the driver in the link. You don't pull a trigger you make a slight turn with your wrist and it goes in the direction you turned to the degree you turned. Hard to explain but very intuitive.
You can not drive screws into wood but you can do finesse tasks.
I did two months of electrical work with one. Connecting conduit, opening and closing conduit boxes, hanging dozens of lights. Really saved me. It is of limited use but it will do what you need it to do. It is very light and the battery lasts forever.
Good luck
Dewalt finesse screw gun.
2/13/18       #3: Tightening RTA Fittings ...
Stu
Bill,
Thanks very much, I'll look into this.
2/13/18       #4: Tightening RTA Fittings ...
Scott Markwood
Website: http://www.Hafele.com/US
Stu, I'm Häfele America Co.'s trainer and though I feel your pain we can't suggest using any a power tool for tightening the cams on a Rafix connector. Driving the bolts into the side panels? All day long, but not for tightening the cams. How about a T-handle ratcheting driver? It would have to have a 2" long bit in it to clear the magnetic chuck, but that would at least change the ergonomics. Wera has an excellent gearless ratchet that could be just the ticket.
2/15/18       #5: Tightening RTA Fittings ...
JP Member
I have had this impact and drill for 8 years now. I use the impact everyday. It is small and light and runs a low risk of breaking things like the bigger ones can.
T handles are decent, I used them a lot when I was working on my dirtbikes all the time.
You also might check out an air or palm ratchet. A 1/4 inch air ratchet doesn't have much juice and you could regulate it for even less.
Makita Impact Driver
