Subject: Re: Pullout Table Hardware
3/10/18
Ron Member
A commercial customer has requested that I install a few pullout tables in his retail wine shop. Fold down support legs are not wanted.
The tops will be recessed in a 24" deep base cabinet, frameless, full overlay construction. The opening is simply like a tall drawer opening that measure approx. 8" x 30" wide currently with a false front.
My first thought was to install full extension or over-travel drawer slides. Attach the top - like an upside-down drawer- and possibly add flip down hardware for the drawer front.
In my research, I can't find any undermount hardware that support more than 60kg (Blum Movento). I'd think they would require a few hundred lbs considering folks leaning on the table with a full bottle of wine on it. I'm sure I can conjure up something shopmade, but I like the thought of some nicely engineered slides. The Haefele units are way too expensive at $348 each. Didn't find anything at Selby as well. Any suggestions?
Thanks in advance.
3/10/18       #2: Pullout Table Hardware ...
As for design parameters, I think you overestimate the expectations for this 24" x 30" table top.
People unconsciously size up furniture and usually behave accordingly. A table top with no visible support, and preferably a thin profile, will read as "sufficient but do not sit or lean on". Full extension also has a bit of wiggle, so that will add to the user's perception of durability.
Of course, there is the unknown - how use of the product may affect behavior. In stairs, my thought was always on the 300 pounder with 4 martinis in him. Will the rail support him? Should it?
That should ease your hardware selection.
3/10/18       #3: Pullout Table Hardware ...
Derrek
Hafele has some pull out table options. The nicest I have seen lately are through Richileu hardware. Super nice quality and very nice hardware. Several options available
Richelieu
3/11/18       #4: Pullout Table Hardware ...
Dan
Hafele has two pull-out tables, the Rapid Pull Table, 505.58.703, or 505.58.103(two finishes). Also the Top Flex Pull-out Table, 505.70.200. Neither one of these is as expensive as you mentioned if you are a regularly buying manufacturing customer of theirs. The Rapid Pull out has a capacity of 220 lbs.
3/11/18       #5: Pullout Table Hardware ...
Bob Carreiro
Custom Service Hardware (CSH) have 130# over-travel side mounting slides. Just used them on a kitchen job for pull-outs. You can install one pair under the left apron, and another pair under the right apron. 260 pounds ought to be sufficient.
3/11/18       #6: Pullout Table Hardware ...
Ron Member
Guys, thanks a lot for the ideas and David, a very interesting way of thinking about it.
