Subject: Re: Cope and stick question
4/4/18
Mike Fuson
I currently use grizzly 3/4” bore stile and rail cutters. I was thinking about going to freeborn cutters with the eased edge slot cutter, currently sanding that part by hand which is a pain. I’ve got a couple questions, how much of an eased edge does that cutter do? It looks slight but I don’t know. Are there other manufacturers that have this feature on their cutters, freeborn is the only one I’ve seen that has it? I would look into insert tooling but evidently that is only available for 1 1/4 bore and I only have 3/4 for the cope and stick. Are there any other options that I’m not thinking about?
4/4/18       #2: Cope and stick question ...
Nathan
Byrd makes insertable 3/4" bore cutters. We currently use them for end cuts on doors. You can get eased edge inserts for them too.
4/4/18       #3: Cope and stick question ...
Matt Calnen
Mike, why do you want to switch to the eased edge? I have four 3/4” shapers, and run both freeborn and grizzly cutters(although phasing out the grizzly cutters) and don’t have to sand that edge. In fact, most of my customers want that tight to the panel look. On occasion, you have to run a stick through twice, but no need to break that edge.
4/4/18       #4: Cope and stick question ...
Mike Fuson
Thanks Nathan for the info.
Matt, there are a couple different purposes. The eased edge allows for stain to go a little farther back in case there is a little door shrinkage then there wouldn’t be as much or any raw wood showing.
4/5/18       #5: Cope and stick question ...
Jim Clark  Member
Don't you stain your doors before
installing in the frame?
4/5/18       #6: Cope and stick question ...
Chuck
Mike, I use 1 1/4" insert cutters from both Byrd and Freeborn on my 3/4 ' spindle shapers. I just use a 1 1/4'' to 3/4'' bushing.
4/6/18       #7: Cope and stick question ...
Mike Fuson
Chuck, I hadn’t thought of using a bushing and I’ve done it before for other cutters. Just had occurred to me. I’m looking at the 3/4 Byrd cutters, looks like after the initial investment it’s cheaper in the long run.
4/23/18       #8: Cope and stick question ...
kevin berthelot
Mike, I have a set of Freeborn insert, eased edge cutters I'm looking to sell. If you are interested. They have a 5/8'' tongue.
4/24/18       #9: Cope and stick question ...
Jr Lee
Website: http://www,leecabinets.com
Kevin what is the Freeborn part numbers so I can look them up. i might be interested.
Jr
4/24/18       #10: Cope and stick question ...
kevin berthelot
F27972
