Subject: Re: Pre-glued Dowels
Pre-glued Dowels
4/9/18
Stewart Member
Okay, as I am getting deeper into the dowel joinery, I'm changing my mind on a couple of things. I'm really considering the pre-glued dowels to save on clean up time at the machine. I'm just not sure how much water to dose in the end holes. Should it be "running" out when testing at the machine before dowels are driven in? How do you know you've gotten enough to activate all the way around?
4/9/18       #2: Pre-glued Dowels ...
Stewart,
What brand machine is it?
The two bore and insert machines I have used use time as the variable to change how much water is injected. You should not have water running out of the hole.
Call the manufacturer and get their baseline for water injection.
Then shoot a dowel grab a pliers and pull it out after a few seconds. You will be able to see how much glue “melted”. It won’t look like it completely melted but you will see transfer to the hole. Get it to where you think it’s right and let the dowel sit for 20 minutes. Then try and pull one out. It won’t always be impossible but it will be close.
Water should not run out the hole. Our current machine shoots the water at an angle, it bounces off the bottom and hits the top and sides.
Good luck!
4/10/18       #3: Pre-glued Dowels ...
Stewart Member
We use a Gannomat drill and dowel. Yes, the timing of the glue nozzle is in milliseconds. If you have experience with this machine, it would help me to know where to start. Otherwise, looking for "transfer" is a helpful tip. Seeing that wood doesn't always react well to water, I didn't want to cause any issues with swelling.
4/10/18       #4: Pre-glued Dowels ...
Bill Member
It takes very little water. I would call gannomat for a starting point. Even if you did not buy it new I am sure they would help you.
4/10/18       #5: Pre-glued Dowels ...
Stewart Member
Thanks, Bill! On the other end - meaning the face holes - I am drilling 16 mm deep (15 mm insertion). My material is 19 mm. I want to make sure I've got the best bite so I was thinking of using a regular titebond yellow glue here. Does this make sense or am I asking for trouble?
4/10/18       #6: Pre-glued Dowels ...
Bill Member
The other side is more difficult. We do use a glue like Tightbond. You want the hole deep enough so extra glue has a place to go but not so deep that it is not pushed too far up the flutes. Our hole is 2mm deeper than the dowel penetration. The link has some good info.
What I found over time was that the assemblers will not use enough glue, too much and it squeezes out so they lean towards less. Everyone's idea of enough is different.
I ended up getting a some Jolly Colla glue guns. They were $3,000 in 2014 and they are still working fine.
http://www.omal.eu/en/products/gluing-system/item/jollycolla.html
They are not cheap but It is capable of putting out a metered amount of glue. I set up a program on the CNC to drill holes in sequence deeper and deeper. We then set the glue gun to fill the first hole, lets call it the deepest. Push the panels together and glue squeezes out, too much. Move on down the line until you find one that is the perfect depth. Push it together then pull it apart. See how the glue spread around the dowel without squeezing out.
We then created a glue setup board. It is a board of know thickness with hundreds of 8mm holes drilled in it to the correct depth. In the morning they set the machine fill one hole on the test board and go. Everyone is happy. Glue doesn't squeeze out and the joint is not starved.
There may be an easier cheaper way to do this but I am happy with this method, it is consistent.
We did use Lamello glue bottles set up for dowels. They were not inexpensive either and only lasted a couple years but they did work.
Here is one, I never bought anything from this place but they came up in the search. There is a collar on the bottle that limits the amount of glue on each push. For $110 it really does a good job.
Dowel Technical Info
4/11/18       #7: Pre-glued Dowels ...
Stewart Member
Bill, very helpful info! Did you find any difference at all using the "thicker" normal yellow glue as opposed to the "thinner" dowel glue? In other words, as long as the amount is correct, will I have issues just using Lamello's glue bottle for dowels with the thicker stuff?
4/11/18       #8: Pre-glued Dowels ...
Bill Member
We only used "regular" glue so I can't say.
5/1/18       #9: Pre-glued Dowels ...
On the panel face we use Titebond Original with a Lamello pressure pot system that injects a measured amount. It is a bit of a pain to maintain but works well. In the bore & insert machine we use the recommended glue which is quite thin. No maintenance problems as long as it is kept clean every day. When we first got the B&I machine we did tests to see if we would use pre-glued or not. They seemed to hold OK but not as well as using glue. Just make sure you have a cover on the dowel hopper or dust will collect on the pre-glue dowels and keep them form holding as well. We've tested complete cabinets, to failure. Most of the time a big patch of the melamine board is torn out around the dowels.
