Subject: Re: Shelf Life for Rolls of Edgebanding
8/7/18
Stu
I thought I had read somewhere that edgeband can go bad if the banding isn't used within a certain timeframe. The thought was that the primer starts to deteriorate. Is there any truth to that? We have a couple full rolls that I'd like to use, but they're 2 years old which got me to wondering...
8/9/18       #2: Shelf Life for Rolls of Edgebanding ...
Stu
Anyone?
8/9/18       #3: Shelf Life for Rolls of Edgebanding ...
Russell Isaac Member
In my ignorance, I have used PVC edgebanding that is older than 2 years... I never had a problem yet... I imagine that if there was an issue, it would show up almost immediately. A test run should tell the story.
8/11/18       #4: Shelf Life for Rolls of Edgebanding ...
Mark Bruins
Stu- Not sure if you are using pre-glued or not. I use pre-glued and have partial rolls of red oak and mahogany that worked fine after 4 years.
8/11/18       #5: Shelf Life for Rolls of Edgebanding ...
Stu
Thanks for the posts, I'm using automatic edgebanding. It never even occurred to me that there could be any issues, but thought I did see it mentioned awhile back.
8/13/18       #6: Shelf Life for Rolls of Edgebanding ...
Chipbored
I too have heard this but only really as an urban myth or from sales reps.
Have used 3-4 year old banding with no issues. Only time I've ever seen an issue sort of related to this is when we got a faulty batch of edging, the primer was defective and the tape came off very easily.
Maybe you could ask edgetape supplier?
8/18/18       #7: Shelf Life for Rolls of Edgebanding ...
Derrek
We have had issues with older 1mm pvc. When end trim would hit it was brittle and would break. Tried a bunch of things and switched to a different role of eb and fixed problem
8/27/18       #8: Shelf Life for Rolls of Edgebanding ...
Bob Stern
2 mil PVC will definitely go bad.
It can get very brittle a chip instead of cut.
I don't think you would have this problem with thin tape.
