Subject: Re: Short Undermount Slides
8/9/18
Does any manufacturer make an soft close undermount slide shorter than 9"? I would find it worthless by my client wants a 10" deep inset face frame cabinet with undermount slides for the drawers.
I assume a 9" slide is about 9 5/8" long. Behind the FF I'll only have 9 1/16" unless I can do something to the wall to extend the cabinet inside of it.
Figured I'd try the easier route with shorter slides.
8/11/18       #2: Short Undermount Slides ...
JP Member
https://www.richelieu.com/documents/docsGr/106/251/0/1062510/1395238_hd.jpg
8/11/18       #3: Short Undermount Slides ...
Looks like they only go down as far as 9" also.
8/11/18       #4: Short Undermount Slides ...
TonyF
Leo G:
Not sure how important the soft close is, but could you have a drawer with a thicker bottom and just use 8" full extension glides bottom mounted on a dust panel behind the face frame?
TonyF
8/12/18       #5: Short Undermount Slides ...
That's what I think I'm going to have to do. I don't see anything anywhere that has an 8" undermount soft close slide. Everything is just the standard by 3"
8/12/18       #6: Short Undermount Slides ...
Steve Member
How big are the drawers (vert), weight etc? Rockler sells short ball bearing slides (6" I think) for jewlery boxes and so forth, not soft close.
8/12/18       #7: Short Undermount Slides ...
No problem getting short ball bearing slides.
8/23/18       #8: Short Undermount Slides ...
Chris
drill holes in the cabinet back or leave part of the back off. We sometimes do this
