Subject: Re: Door stop
Door stop
11/20/18
Tony
Guys, we are just finishing up an install on a whole house of cabinets. All inset doors, BLUM inset hinges with face frame mounts. We have a situation on a large wardrobe cabinet in the master bath. When the doors are open, they swing back and hit an area of window casing that has a shadow line/bead incorporated. The doors just barely touch the trim but the customer (understandably) is not satisfied. I intend to do whatever it takes to remedy this, including rebuilding, which I obviously would like to avoid if possible. I have not been able to find a restrictor-type clip add-on for this hinge. I have thought about using a lid stay to prevent the door from swinging past 90 degrees but that seems more like a last resort. Do any of you have info on the availability of a restrictor, or any other suggestions. The doors are maple, flat panel, 16" wide by 56" tall. Thanks for any ideas.
11/20/18       #2: Door stop ...
See if they would agree to a bead chain from the cabinet to the door. Smaller than a lid stay. Especially if you keep it near the hinge side. How about a clear silicone bumper on the casing?
11/20/18       #3: Door stop ...
Blum sells restrictor clips for most or all of their hinges. If you can’t find one. I would look at Salice and see what they have for their hinges. The door hole pattern is the same.
11/20/18       #4: Door stop ...
Bob
Salice definitely has a restriction clip. I have used them on several occasions to keep doors from hitting decorative hoods. Not sure of the part # but Dennis Beam will know.
11/20/18       #5: Door stop ...
I mean ditch the Blum and swap the hinges for Salice if the Blum restrictors don’t work.
11/26/18       #6: Door stop ...
Chris
We use Blum 110 insertas for 99% of doors. This model hinge has a restrictor clip that mounts in the hinge cup and restricts the door from 110 to 87. It isnt a hard stop though..Still a little spongey up to 90/93 Id say. Other Blum hinges have other restrictor clips...but not all models do. Dont know anything about the Salice
