Subject: Re: Would changing overlay of hinges help rubbing with double door cabinets?
12/29/18
Rich Member
I have some cabinets that I repainted where a few of the cabinets with double doors and no center stile rub together. I think a few were rubbing before as I just bought the house but the paint I added to door and frame tightened the tolerances. I have the hinges adjusted outward the max amount of both sides but they still touch in middle.
Would getting a similar hinge with a larger overlay help me? I am trying figure out what changes on the hinge with a larger overlay? Does the offset between the cup hole and the bracket that connects to the frame actually change. ie... will getting the same hinge with a different overlay shift the door right/left relative to the frame? I was thinking maybe it does but then I was also thinking that maybe just the 'arm' of the hinge is longer if you have a larger overlay so that the outside of the door doesnt smack in to the frame as you open it. ie a door with a larger overlay on the hinge side might need a longer arm so that the outside of the door doesnt smack in to the frame as it opens.
my backup plan is to get a trim router and trim the frame a bit in the hinge area to make the frame opening 'wider' but I would love to but it would be much easier to buy new hinges of playing with the overlay helps.
I have fairly issues blum hinges.
View higher quality, full size image (800 X 800)
12/30/18       #2: Would changing overlay of hinges he ...
D Brown
Perhaps you could joint the meeting edge off one door no new hinges.
12/30/18       #3: Would changing overlay of hinges he ...
John Member
Route 1/8" off the edge of the faceframe where the hinges fit, as you said. Fast and invisible.
John
12/30/18       #4: Would changing overlay of hinges he ...
Collin Parker  Member
Website: heritagewoodwright.com
yes you could easily fix this with new hinges. just need to figure out the current hinge overlay and then make sure the new one has a min/max overlay range in which you require. Id spring for the softclose since you are replacing and the upcharge is minimal.
*this is all assuming there is room to move the doors outward without hitting anything and that they are not outdated "lipped edge" doors.
12/30/18       #5: Would changing overlay of hinges he ...
D Brown
Moving the outside edge of the door over in some cases will cause the adjacent drawer or doors to be out of line.
12/31/18       #6: Would changing overlay of hinges he ...
Gary
We do this often. You only need to change the hinges on one of the two doors. 1/8" more overlay on one door has always fixed it for us.
1/1/19       #7: Would changing overlay of hinges he ...
geoffrey grice Member
If the hinge pictured is the one that you are using there is not very much adjustment. you can take a pencil and mark above a below on the face frame where the hinge screws on. take a utility knife a trim off enough where the hinge sits to allow the hinge to recess into the face frame a little more then you don't have to buy anything
