Subject: Re: Blum minipress
Blum minipress
1/25/19
John B Member
Website: http://woodmanseewoodwrights.com
I recently bought a second Blum minipress that included a 7 spindle boring attachment for boring shorter cabinets than I want to bore in my 23 line borer. It's a CD model, and according to the limited instruction manual, it looks like I'm lacking a stop that controls the depth of the bores. From the looks of the diagram it's a 2 sided plastic piece that screws together on a shaft. Anyone on here have a similar setup that knows what I'm talking about? Tried finding pics online but so far, no luck. Also not sure where even to look for parts. I've been on Blum's site but didn't see it listed in any of their parts drawings. Maybe I can just make up a collar and have it work but looking for a little input first.
1/25/19       #2: Blum minipress ...
B Member
Yes. It is basically a plastic bolt that threads into the bottom of the head. The bolt hits the tabletop and stops the whole mechanism. You should be able to make something to retrofit it. Even screwing bolt down into the work table that stops it would probably work.
1/26/19       #3: Blum minipress ...
Ed
I remember getting the part you are missing with the 7 spindle attachment. It is a plastic piece maybe 2 1/2" long that snaps on depth adjustment shaft . You should call your Blum distributor and have them look up model number on 7 spindle attachment. They should be able to order one.
Ed
1/26/19       #4: Blum minipress ...
Is this the piece you are talking about or something different?
1/27/19       #5: Blum minipress ...
Ed
It does not appear to be there, the part snaps on the depth adjusting shaft directly behind main air piston , just below the knob/wheel
Ed
1/28/19       #6: Blum minipress ...
John B Member
Ed, I think you're correct. it looks like that's what I'm missing. I will try calling Atlantic Ply, that's who supplies hinges and guides. Bought both my units at auctions for decent prices but boy, their instruction books suck.
Thanks for all the input.
1/28/19       #7: Blum minipress ...
BobbyS
Years ago I wanted to set depth for my mini press for odd items, but did not want to hassle resetting it, and then just have to put it right back.
Sooo, I simply cut a stop block, and secured it place between metal columns, so it would stop the drill head at the depth desired. I don't remember the details, but it was an easy 5-minute solution.
It worked great, and never seemed to cause any problems with the machine otherwise. Easy Peasy.
4/20/20       #8: Blum minipress ...
karasj Member
Website: http://mebprom.com
Hi guys.
I'm from Ukraine, so badly speak English. I'm sorry.
Please evaluate my idea (dust extractor for Blum minipress):
https://youtu.be/df8QqOJG5VY
4/20/20       #9: Blum minipress ...
Looks like it is effective.
