Subject: Re: Small portable gluepot edgebanders
2/10/19
Oggie Member
I'm thinking getting one of those small portable gluepot edgebanders, but I've been able to find only very little info on the usability of those or the quality of the results.
The ones I'm talking about are like this:
1. http://maksiwa.com/usa/edge-bander-cbce.html
or this one, which seems to be the same, only branded differently:
2. https://mcfaddens.com/p-136900-wurth-portable-edgebander.aspx
I do not need portability, the main reason I need it is to be able to move away from hot air preglued banding (because of it's very limited local availability in other colors besides white) and the price of the bigger machines which are now out of my range.
It would be used for PVC edgebanding on 3/4 melamine, and the thickness of the banding would not go over 2mm (most likely around 1mm or less 99% of the time).
Trimming would be done with something like this:
http://maksiwa.com/usa/edge-trimmer-rbb1000.html
The main questions is:
- Does (can) this setup produce comparable results to those produced by bigger machines in terms of quality? (I know it can not compete in terms of speed, quantity, usability and so on, but I'll leave those concerns for next year).
I know the final results mostly depend on what you do after gluing (trimming, beveling, sanding, buffing...), but is the actual gluing part good enough so that it won't be the limiting factor in the overall quality of the edgebanding, assuming subsequent operations are done properly.
The long term plan is to eventually switch to a bigger machine but that is not possible right now.
Any thoughts on this are appreciated.
Thank you
Oggie
View higher quality, full size image (700 X 500)
2/11/19       #2: Small portable gluepot edgebanders ...
Ryan
I know some people don't like doing this but have you looked at financing a larger machine. We have a Cantek mx350 which even has premill. They make a cheaper one that does not. When we compared the cost of the payment to the amount of time saved it was a no brainer. The payment is just over $200 a month. When you consider the time saved by having a bander that your panel will be perfect when it comes out the other end is wonderful. Any time savings can be used to build boxes or something else that is making you more money and increasing the amount of work you can put through. It also allowed us to get into frameless cabinets and be able to sell them at a good price and make money at them. Frameless cabinets are where the money is at. When we bought it we only used it for adjustable shelves for the first couple of months.
2/11/19       #3: Small portable gluepot edgebanders ...
Oggie Member
Thank you for the reply.
The machine you suggested would certainly be a better option in general, but maybe not in my current circumstances.
The shop I have is not very suitable for cabinet building, it's small and has few obstructive walls and stubs here and there that complicate things.
At the moment, besides table saw and boring machine (which are to heavy to move all the time), almost any other tool has to be "brought into place" to do the required operation and "stored back somewhere aside" after it had been used in order to free space for something else . So, until I move to another shop there is really no space for anything bigger right now than those little ones.
"Proper" edgebanding machine is the first thing on the shopping list for the new shop.
But I need something soon for few upcoming projects that will be done in my current shop.
2/11/19       #4: Small portable gluepot edgebanders ...
Jared Emery
You might have thought of this but didn't mention it in your post. If I were in your position and only needed better banding for a few jobs, I would outsource it to a local shop with a decent bander. It's the cheapest, simplest and best quality solution by a long shot. If that's not an option, consider buying a portable bander that you could still use for curved parts after relocating to more space. Otherwise you end up with a tiny bander that produces poor to mediocre quality and hasn't paid for itself in the few jobs you have lined up.
2/11/19       #5: Small portable gluepot edgebanders ...
Ryan
If you want something that is small and will store easily I would look at the festool one. It will do curves also. This way when you get in a shop and have room for a larger bander the festool will still be useful just for curves. It is also handheld and or will mount in a table.
2/12/19       #6: Small portable gluepot edgebanders ...
Tadhg
Oggie i bought one of these and trimmer
I have only used it once so far but i agree with other guys I saw it on display in Iwf in atlanta and it looked really impressive but in reality its not now in saying that i prob have tweak it to get it running properly
The trimmer is very tricky and gets jammed quiet a bit I looked for longest time to buy a good quality edgemaster or virtulex and missed out by a day for one Im in same position regarding space but by time you buy both its same as size of virtulex Your welcome to come and see it if you want thanks tadhg
2/12/19       #7: Small portable gluepot edgebanders ...
Oggie Member
Thank you guys for your valuable insights.
My reasons for leaning toward those two machines stem from the fact that I am a one man shop. If I opt for having an external service for edgebanding than it means I am the one who has to load the parts, drive them to that other shop and than come back for them when they are ready, repeating all loading, driving and unloading work myself. Work is not a problem, but the time is. With current traffic situation in Orlando FL, it would probably cost me 1-2 days just for that, unproductive part of work, and the value of of that time would reach the cost of those machines in less than two weeks.
And that is just a tiny bit of all things that get disrupted, no time and space here to elaborate more, but I'm sure those of you who have started as (or still are) one-man business know how much does it cost you to stop everything what are you doing to just pick up a ringing phone, let alone leave the shop and go somewhere in the middle of the day.
Currently, with my small hot air edgebander and manual blade tool for trimming I'm able to edgeband approximately 300 foot of PVC banding in about 2 hours. The 300 foot roll of white, preglued PVC band costs me a little bit less than $30.
Local shop that does edgebanding asks $1.50/foot, so it would be $450 and one day in time, for what I do myself for 2 hours and $30.
Of course, hot air, preglued PVC edgebanding is far from perfect, certainly not comparable to what they are able to produce. Hot air softens the PVC band, and the plywood/melamine board texture telegraphs through. But, most of my customers (lower end rental properties) are not perfect too, and do not care much for such things, they are interested only in price (the lower the better; if you offer them finest quality kitchen for $3000, and the worst quality one for $2900 they'll choose the latter), so it works ok for now.
But, from time to time I get to do some commercial offices and then I spend a lot of time gluing edge bands cut from laminate sheets with contact cement, and lot of manual trimming, filing, cleaning the glue and so on. The results are good, but not worth the effort.
So, I was hopping that I could at least save myself from gluing those with contact cement, and even if I still need to do most trimming manually after that, it would still be a considerable improvement for me in comparison to what I do now. Especialy if I could use manual, double side blade, trimmer that easily cuts PVC, instead of trimmer router you need to trim laminate sheets.
I have also tried to use preglued bands in the same color/design as the sheet material itself, but it was really bad: even if they were more than twice the price than simple white ones I buy locally, they were really bad: they did not stick well at the temperature they could withstand, and if you use higher temperature then they shrink, deform, wrinkle and so on... and still did not stick much better.
I have looked at the Festool, but don't know much about those either, has anyone tried to use it to glue 300-600 ft daily from a roll, by mounting it on a table and sliding straight edge parts through it?
I suppose it is well suited for gluing one part at a time, but what about 50 of them: i.e. how do you start it for next part, how do you stop it when the part is through, how do you cut (or do you need to precut) band for each part... all those things can complicate workflow if the machine is not well suited for such job, and both of your hands are busy holding the part you try to edgeband....?
Well, all that being said, is there any "beginner's" edge banding machine, that someone is familiar with and can confirm that it produces nice results (even if it may require additional operator's work on a parts after the machine in comparison to professional ones), that is smaller in size (maybe even movable if it's mounted on a platform with wheels)?
Tadhg, you mentioned Edgemaster or Virtuex, can you specify which models you had on your mind?
Thank you all,
Oggie
2/12/19       #8: Small portable gluepot edgebanders ...
Gary R Balcom Member
Oggie,
We have two of the festool machines we use for curved edges. We run them every day. Great machines for the price.
2/12/19       #9: Small portable gluepot edgebanders ...
Oggie Member
I have no doubt that they are great for curved (or straight) countertops and such things (where there're usually few per project), but are they good enough for efficiently banding a lot of (120+ pcs.) short (< 30") straight edges in a bulk, since that is a problem I'm trying to address?
2/12/19       #10: Small portable gluepot edgebanders ...
Jared Emery
I also have the Festool Conturo. You have to cut the banding a few inches longer than the part and feed it into the machine for each part. I imagine it's the same for all portable banders that don't have a cutoff mechanism. Clamping and unclamping the panel takes longer than banding the part. I've considered buying the gizmo that lets you mount it upside down in a table. It'd be useful to band beveled edges quicker than spray glue.
2/12/19       #11: Small portable gluepot edgebanders ...
Oggie Member
Jared,
my small hot air edgebander has a cutter (guillotine) that operates by hitting the lever with your palm, and then you just manually push the banding few inches forward and it's ready for the next part.
It works ok that way because you feed the band manually by pushing the piece yourself through the machine, and thus you control start, speed and stop.
I believe this Maksiwa (and other similar machines) work the same way, only they use glue roller instead of hot air blower.
On the other hand, it seems that the Festool has some "Start" button that you need to push at the start of each edging, and the band need to be precut to certain length and inserted into the feeder prior the operation, otherwise it will not stop by itself once your part is through. Also you have to synchronize your push with the start of band feed after you hit the start button... I'm not sure if I'm right about all this, but if I am I think that may not be the best solution for processing large number of straight short pieces, simply because of those additional preparation steps each piece requires.
Anyway, I think it's a great machine for doing countertops or shelves(straight or curved) and I have plans to purchase it in the future, but right now all my countertops are made with laminate sheets glued with contact cement, including edges too. But I don't have many of those and the speed is not concern, whereas with usually 120+ cabinet parts per job I would prefer something with less steps per each cycle.
But, like I said, I do not have direct experience with it, my opinion has been formed from watching few youtube videos. If anyone has managed to setup that machine for efficient edgebanding of large number of straight and short edges of cabinet parts and share that with us that would be great.
2/12/19       #12: Small portable gluepot edgebanders ...
Tadhg  Member
Oggie virtulex eb 135 safety speed 70 ha
The 60 ha is hot air model only. Other is gluot. But there 10 thousand. For glue. 7500 for air. But I read posts on here saying stay clear of hot air models. I was one man shop at start with min room. So I know where your coming from. And it’s hard to fork out that much. So. As I said for money for makwisa it’s cheapest option for unit this small if I get mine run like demo model in Atlanta. I’ll be really happy. As I checked several of samples and they were perfect. I’ve only ran it for few short pieces but have few kitchens comming up so hopefully I can dial it in right thanks Tadhg
2/12/19       #13: Small portable gluepot edgebanders ...
Oggie Member
Tadhg,
yes, that's what I'm basically interested in: can it produce good results - doesn't really matter now how, cause I'm sure I will find acceptable solution somehow. The only question is: is the gluing operation alone good enough so that will not be a problem in finished look if the subsequent operations like trimming, beveling, buffing... are done good.
All I'm expecting from that machine is to enable me me to apply various color edgebands by using melted glue, because preglued hot air edgebanding did not work well for me in the past, as described in one of my previous messages. What happens after gluing is not giving me problems right now.
2/12/19       #14: Small portable gluepot edgebanders ...
Tadhg  Member
I can’t tell you bout color options. All I run is birch. And. Pre finish maple. I never run white or any other color as most of my clients want edges same color as paint. On doors but there are great bargains on buy and sell on threads here. I missed out on virtulex. Buy one day. Gutted it was barely used and great price. So if you can wait ide search and search. Mabey you have better luck tadhg
2/12/19       #15: Small portable gluepot edgebanders ...
Oggie Member
I suppose birch or maple, or any other genuine wood banding should be good regarding the heat caused problems.
I would be applying PVC edgebanding to melamine boards and it needs to match melamine color wise. But any other than white is not readily available as preglued hot air version so I have to order it and wait for it. And those that I tried before were not good: if the temperature is high enough for good bond - than it's to high for the PVC, it shrinks, deforms, wrinkles, softens to the point that it all wood particles in the melamine cut or layers in the plywood cut telegraph through. If I use lower temperature to prevent those problems, than the glue bond is not strong enough, you can peel it off easier than the low quality painters tape off the dusty wall.
My hope is that the pot-glue system will produce good bonding while not exposing PVC band to temperatures that will cause above mentioned problems (as the hot air system does), and that the glue line will be uniform (or hopefully invisible) along the edge.
Just need someone to confirm that is actually the case and not just my fantasy.
