Subject: Re: Custom Drill Bit
Custom Drill Bit
2/18/19
Puzzleman Member
Does anyone know of a company or two that will make a custom drill bit?
I am looking for 5 copies of the bit.
2/18/19       #2: Custom Drill Bit ...
If it's a custom diameter, nearly every machine shop could cylindrical grind down an existing bit and resharpen it for you. If custom ground flutes, you'll need a shop with a 5 axis grinder. Way cheaper to modify existing bits.
2/18/19       #3: Custom Drill Bit ...
kevin basto
AB tool. Lincoln,CA. mostly CNC tools but sure they could do it, not sure the price tho. Is it diameter or shape you are looking for?
2/19/19       #4: Custom Drill Bit ...
Puzzleman Member
I have attached the bit design that I am looking for.
This is for drilling a hole to put an insert inot a wood frame with clearance for the leg to screw in.
View higher quality, full size image (1217 X 1618)
2/20/19       #5: Custom Drill Bit ...
Dan drb woodworks
Ct saw and tool , Stratford ct
