Subject: Re: Knock-in insertion ram hinges
2/21/19
Steven
I have been using Blum hinges with dowels and knock them in with a mallet. My supplier has a compact Blum 38N soft close hinge that is only available as a screw-on fixing or knock-in with insertion ram only. I don't have an insertion ram and was wanting to know if there is any reason I couldn't/shouldn't knock them in with a rubber mallet. The picture shows that they have dowels on them too so I'm wondering what's the difference between knock-in and knock-in with insertion ram only?
2/21/19       #2: Knock-in insertion ram hinges ...
Mark B
I'm pretty sure that you're technically not supposed to use a mallet on any of the hinges. Blum also sells a "knock in tool" that distributes the blow evenly.
Knock-in Tool
2/21/19       #3: Knock-in insertion ram hinges ...
Tom
In the past I have made a jig similar to the knock in tool and inserted it in the chuck of my drill press and used this to press in an occasional odd hinge . It works surprisingly well .
2/21/19       #4: Knock-in insertion ram hinges ...
mike
I think the key is that the insertion tool or knock-in tool applied pressure right at the dowel/screw. On the occasional jobsite assembly I noticed the hinge would sit proud if not final tapped right at the screw
2/21/19       #5: Knock-in insertion ram hinges ...
duster
Look into the Inserta or Expando hinges.
A bit more money per hinge, but you don't have to hammer them in...
2/21/19       #6: Knock-in insertion ram hinges ...
Kip
No reason whatsoever to not use a mallet on the compact hinges. I’ve installed thousands upon thousands with a mallet. I’m sure the insertion tool would be nice though. I’m sure Blum would frown upon the mallet too lol
2/21/19       #7: Knock-in insertion ram hinges ...
Steven
Good to know, thank you all.
2/22/19       #8: Knock-in insertion ram hinges ...
james e mcgrew  Member
Switched to inserta years ago for many reasons,
2/27/19       #9: Knock-in insertion ram hinges ...
Steven,
Blum advises against using a mallet to knock in the hinges with soft close without the use of an insertion ram. There exist a the chance that the soft close mechanism could be damaged. We offer the same caution here at Salice.
It is something like the warning signs on the fuel pumps at the gas station that warn "Not for human consumption". :)
Best of luck,
Dennis
2/27/19       #10: Knock-in insertion ram hinges ...
Steven
Dennis,
Thanks for the warning from Blum on damaging the soft close mechanism. I have to say, a warning not to drink gasoline(not sure what state they have those in) being analogous to this seems a little strange though.
Good luck to you too.
