Subject: Re: Tenoncam
Tenoncam
4/3/19
Thad Wende Member
Website: http://www.houzz.com/pro/twende/wende-woodworking-...
Who on here is using Tenoncam with Frameless construction and 18mm Pre-finished Birch plywood boxes? We are nested base with a half line Andersen CNC and have 2 fixed 32mm horizontal bore glue dowel machines setup for our 2 horizontal boring patterns one is setup for all of our decks and the other is setup for or front and back stretcher rails. We are looking for a construction method that would all be handled in the nest with out additional handling or processing of parts. We are a long time CV user and are running Version 11. Looking for feedback from some actual users that made the switch to Tenoncam and what there likes and dislikes are?
http://www.tenoncam.com/
4/5/19       #2: Tenoncam ...
You might try contacting some of these people
Tenoncam testimonials
4/5/19       #3: Tenoncam ...
I suppose I can attest somewhat for Tenoncam as I installed their (Hilker's) cabinets for a short stint of 6 months or so until I got sick.
The best box I have installed. They used Chinese plywood which Tenoncam accommodated nicely, because of it's design.
If you want to hear about the nuts and bolts I recommend talking to Abe as he runs the shop at Hilker's and understands the system thoroughly.
4/6/19       #4: Tenoncam ...
Keith Member
I have been using Tenoncam for the past 11 years. I started out using CV in 2005 and got my first CNC in 2007. Started out using the CV blind dado system and quickly looked to a better system to build boxes. Tenoncam has proven to be a money maker for my business. Simple assembly and well thought out. We recently upgraded to CV 11 and completed the Tenoncam integration within the past month. My opinion is that it is the best built box on the market.
4/8/19       #5: Tenoncam ...
Larry Schweitzer
I looked at their web site. I see that "Integral Finished Ends are all operable from within the same construction method." How are those attached? Case clamp? Pipe clamps & culls?
Will this system meet AWI standards?
4/8/19       #6: Tenoncam ...
Thad Wende Member
Thanks everyone that has posted on here or contacted me directly regarding Tenoncam. We are going to move forward with it and I will report back on how it all goes switching over. Getting his basic package for now then will consider his other packages once we get into it further.
As for your question Larry, finished ends instead of unfinished ends with no applied ends I would assume you would be gluing and clamping those with no exposed fasteners. He has an attribute that can turn off and on the through holes by grabbing the top,deck, fixed shelf, stretcher or what ever and turning on or off those through holes on a per joint basis from what I understand.
4/10/19       #7: Tenoncam ...
What is a cull?
I'm guessing the Finished End would be pinned through the tenon from the inside
