Subject: Re: Shaker MDF doors
Shaker MDF doors
4/7/19
Greg Jenkins Member
I have a small kitchen coming up with Shaker doors that I want to make on my CNC. This is a first for me. I read that I need to use a high grade MDF. Beyond that, I'm short on details. How deep is my recess? Do I recess both sides to make it balanced or just the face? Do people square out the corners?
thanks
4/7/19       #2: Shaker MDF doors ...
Kip
I have found it rather time consuming to machine them. I can make 5 piece doors just as fast, all things considered. I also found them to curl up a bit due to the one sided machining
4/7/19       #3: Shaker MDF doors ...
Chris
I use 3/4" ranger Platinium MDF with white melamine back. 8 mm deep pocket on the face only. 1/16" radius on inside corners
4/7/19       #4: Shaker MDF doors ...
Greg Jenkins
Thanks Chris.
Do you finish the melamine back or just leave as is?
4/7/19       #5: Shaker MDF doors ...
Chris
we sand with 100 and 150 grit and then spray. The melamine back saves us 1 primer coat and seems to help with warpage compared to raw mdf.
4/7/19       #6: Shaker MDF doors ...
Greg Jenkins Member
Perfect, thanks for your help!
4/9/19       #7: Shaker MDF doors ...
Harold morantz
Website: http://morantz Cabinets.com
We have been using 3/4”mdf with white melamine back for years, never had a door warp.
5/12/19       #8: Shaker MDF doors ...
Jason Scott
I cut mine with a large diamond but from riverside tool to clear the center panel. 1/4” deep pocket and clean the corners with a 1/8” end mill.
We also put a small radius on the knives and outside edges.
It also helps a lot to cut down to an onion skin before cutting the pocket, then machine everything and make the final cutout. Onion skinning everything also helps the edge quality if you offset it from the final pass 0.005”.
