Subject: Re: Hidden Doors - Soss vs. Piano Hinge
7/27/19
Brett
Hi,
We do a couple hidden doors per year and was wondering what the rest of you use for hinges? We have used both Soss hinges and heavy duty piano hinges for hidden doors. We have a very experienced cabinet maker in our shop and he swears by piano hinges for hidden doors although I think the Soss hinges look more professional.
7/28/19       #3: Hidden Doors - Soss vs. Piano Hinge ...
Eddie
Soss Hinges here, some people don't like it because the routing time.
7/28/19       #4: Hidden Doors - Soss vs. Piano Hinge ...
Paul Miller
Without knowing your application, I cannot really make a recommendation. If the door is heavy, I would look at Rixsom pivoting hinges. I once did a hidden door that was a bookcase and I used a Rixsom pivoting hinge. Smooth and they can handle a lot weight without any sag. They are a challenge to route for mounting.
7/28/19       #5: Hidden Doors - Soss vs. Piano Hinge ...
I don't like the little round ones as they fail.
7/28/19       #6: Hidden Doors - Soss vs. Piano Hinge ...
Move past those sagging Soss hinges.
Look at the Tectus line. 21st Century design, 3 way adjustable, lots of finishes, and no sagging. The link will take you to an article that explains the hinges, the installation and applications. We have used them on some very heavy doors, with no problems at all. Kits are available for rent with all the jigs you need to route painlessly.
Katz Tectus Article
7/29/19       #7: Hidden Doors - Soss vs. Piano Hinge ...
Brett
Thanks for the responses. I will check out hinges that were mentioned.
7/29/19       #8: Hidden Doors - Soss vs. Piano Hinge ...
kevin basto Member
As David says Tectus is the way!! When you have to come back later to make adjustments its a breeze, just don't forget your allen key! Also Sugatsune makes comparable hidden hinges to Tectus, many finishes and adjustable also, you can never save money in construction.
7/30/19       #9: Hidden Doors - Soss vs. Piano Hinge ...
One of the advantages of piano hinges is absolute alignment. Because the whole length is secured the alignment can't go out. It is very simple to install. There are no special jigs or precise routing needed. It can't go out of alignment over time.
KISS
7/31/19       #10: Hidden Doors - Soss vs. Piano Hinge ...
Leo - I agree - KISS is always a good approach. But Tectus has such a cool factor that it always stops people - they want to look and see how it operates.
If I want to use Tectus and the builder or owner is slow, Then while we are talking, I'll hand him a Tectus hinge. No matter what we are talking about, his conversation slows, and his handwork increase, and he is operating the hinge, turning it over, seeing the parts.... Asking questions about the Tectus. Pretty soon, he is sold.
Try that with a piano hinge.
If you want up your game and gain another skill for your back pocket, Tectus is a good place to do so. The piano hinge is good and solid and predictable, nothing wrong with that. This is where the style or mindset of the maker comes into play. So it depends upon who you are, what the image is you wish to project, and how you like to work. The things you wanted to do when you were back, slaving away, unnoticed, next to Mauricio, fantasizing about "If I had my own shop...."
All in all, vive la diferance.
7/31/19       #11: Hidden Doors - Soss vs. Piano Hinge ...
Oh I agree with the cool factor. They are cool. And they are outrageous in cost. If you are dealing with high end clientele then it's a gimme. But if you are dealing with people that have enough to work with you but not enough to say just do it to anything economy might be the way.
$70 each x 2 or 3 vs $18.00 might open their eyes too. Minimum door thickness is 1" for the smallest model so that might make a difference too.
