Subject: Re: older Brant kd83
older Brant kd83
8/15/19
Tim Bradley Member
Website: http://lastfrontiercabinets.com
Hello, all, older Brant KD83, or as we refer to it as the big green Volkswagon, I have turned just about every nut bolt on this thing, but electrical not so much.
Power up machine, set glue temp, at temp, turn on track, feed rollers etc, all good, then hit end snipe motors , both come on, hit top bot flush cutters, they wont come on,turn snipe motors off, top bot trimmers will come on. trimmers are on one button, snipes each have button, turn all off, turn on trimmers they both come on, hit front snipe it will come on, back snipe will not, turn off flush trimmers, back snipe comes to life, at some point I have managed to get both flush trimmers and the front snipe to run. so all motors work and run, just can not get them all to run, I get no flashing "something not right" button, non of the breakers have tripped in the cabinet, inverter control box seems to be reading all systems go, you would think after all the years I have had my head under the hood of this thing I might remember what it looks like when it is running good, but I think I have a couple extra red led's light up in the cabinet, I don't have the electrical drawings for it and tec support needs them to help troubleshoot, any thoughts on the issue it self and how one finds a electrical schematic for a 93 or 97 machine?, drawing a blank on the year.
Dead in the water and any help would be greatly appreciated
9/10/19       #2: older Brant kd83 ...
COLIN COOPER Member
Website: http://www.redladderco.com
I read on another thread that you should disconnect the power and check the base of the main circuit board. Apparently they can crack and will need to have a new lead soldered on.
