Subject: Re: Ogee profile shaper cutters for stile and rail
9/11/19
duster
I'm trying to find an off the shelf cope and pattern set with a 3/4" wide ogee profile to match some existing cabinets for a remodel. I'm trying to avoid having custom ones made since there are only 4 doors for this project. I've checked all the usual sources, but so far I've struck out. Any ideas?
9/11/19       #2: Ogee profile shaper cutters for sti ...
Eddie
Not sure about your custom knife supplier, but ours (CT Saw) will be cheaper having a Cope and Stick set made than a off the shelf.
9/11/19       #3: Ogee profile shaper cutters for sti ...
Bruce H
I suppose not all ogee details are the same but you might check Freeborn. I have two of their sizes for cope and stick.
9/11/19       #4: Ogee profile shaper cutters for sti ...
duster
I own several Freeborn sets, but the only ogee profile they offer is only 3/8" wide.
I spoke with them today about a custom set, they're $925... ouch.
9/12/19       #5: Ogee profile shaper cutters for sti ...
Mark V.
Duster,
Do you have a picture of the profile you are trying to match?
My first thought was to outsource it since it is only 4 doors, but lately I have had way too many problems/headaches going this route, so I am hesitant to recommend it.
Another option is to have the profile, or sticking, cutters made for a Williams & Hussey or a insert head for the shaper. Run your "molding", groove and assemble your doors with a french/haunched miter, reinforced with your preferred method such as dowels, dominos, stub tennons, etc.
Mark
9/12/19       #6: Ogee profile shaper cutters for sti ...
Gary Balcom
whatever happened to that "rent a set" program I saw on here a while back? I can't remember the name of it.
9/12/19       #7: Ogee profile shaper cutters for sti ...
Mark V.
Just did a job where I couldn't match a cope/stick profile from the usual sources, so W&H molder to the rescue. Cutters were around $125.
Mark
9/12/19       #8: Ogee profile shaper cutters for sti ...
Dustin orth
Call Joe at CGG Schmidt, I have them do all this kind of stuff for us. As said before, a corrugated knife head and one pair of knives and your golden. I don't bother with the matched set either, especially for this little quantity.
9/12/19       #9: Ogee profile shaper cutters for sti ...
Brent Member
Not sure if you have a euroblock or not, but they're great for jobs like this. Most of the time I can have both the cope and the sticking ground onto one knife so it's pretty cheap.
View larger image
https://www.whitehill-tools.com/catalogue.php?pid=4664&cid=1&c2id=52
9/15/19       #10: Ogee profile shaper cutters for sti ...
duster
I do have a router bit that's pretty close to the ogee profile I'm trying to match. Since there are only 4 doors, I think I'll give Mark V's suggestion a try with the haunched miter. Thanks for all the input!
