Subject: Re: banding
banding
11/7/19
Scott Syers Member
has anyone tried heating the pvc banding before running to get an easier cut with gillatine?Holzer 1554
11/7/19       #2: banding ...
Scott Syers Member
this is not my idea btw lol
11/7/19       #3: banding ...
MarkB Member
Would seem you'd need to get it pretty warm to get any appreciable softening and then the concern with shrinkage after it cools?
11/7/19       #4: banding ...
Jared E
MarkB, it's ok, many men have this same issue.
11/7/19       #5: banding ...
Hah...priceless. reminds me of a Seinfeld episode
11/7/19       #6: banding ...
Jeff
I’d just sharpen the guillotine. It sounds like a nightmare. Too soft and it’s gonna bend not cut. Also if you put too much heat in pvc will curl.
11/8/19       #7: banding ...
Rob Young  Member
Website: nutekmachinery.com
Scott,
I've seen companies heat 3mm material, normally to increase it's pliability. Some believe it helps, I would say maybe a little but the bigger benefit was warming up the edging of the 3mm, which in turn kept the glue from cooling down prematurely before the board reached the first pressure roller giving them a stronger joint.
Rob
