Subject: Re: How would you assemble these Island panels?
2/19/20
Matt
Good day all,
Our jobs nowadays almost always have these wide panel type assemblies on the ends of Islands that produce a "Leg" effect. Over the years we've gotten good at doing these but I think we can do better.
Please look at the attached image of two different panel assemblies. If your shop were going to build panel assemblies similar to these, how would you do it?
Specifically, I'm trying to find out:
1) Would you assemble them before painting them? They can get heavy.
2) If you assemble them AFTER painting, what sort of connectors would you use to attach them together?
3) Are there any slide or snap connectors that we should consider using to attach the vertical stiles to the shaker panel?(complete with dedicated joinery machines for cutting slots/ovals)?
Currently we assemble these items before painting using pocket screws and occasionally biscuits/glue.......because assembling them already painted invites a lot of opportunity for damaging the finish. However, lugging these things around in the spray booth is becoming really taxing, the more we increase in business.
I really think we could fly these through the paint booth quicker if we assembled them after painting.
What do you guys do? How would you approach this?
View higher quality, full size image (11848 X 7936)
2/19/20       #2: How would you assemble these Island ...
Edi Silva  Member
Website: silvawoodworking.com
Assemble before finish here, less change to get damage.
2/20/20       #3: How would you assemble these Island ...
Dan Dempsey Member
Website: CSaw.com
Hi Matt,
I think the Lamello P-System may be a solid solution for your shop with this application. The Tenso connector in particular, would allow you to snap your pieces together after coming out of the spray room. Use the Tenso with a bead of glue and these will go together just fine. I'd recommend using a sanding block to scuff up the components where the glue will be used so that it absorbs into the material.
I'm attaching a Youtube video that shows The Lamello P-System in great detail, starting at the 5:00 minute mark. Then, at around the 8:00 mark, it shows a sanding jig that helps remove some of the finish off a plywood sheet so that the glue adhere's better. Hope this helps!
Video
2/24/20       #4: How would you assemble these Island ...
Matt
Dan, thanks for that link. I am interested in the lamellos, are you a user or a vendor? Feel free to email me if you are a vendor.
If I were to consider this, I would not want hand-held slot cutters like the individual in the video. I would want stationary machines with presets. Is that available?
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
