Subject: Re: Blum Pocket Systems
Blum Pocket Systems
4/15/20
Michael Sanders Member
Anyone know if this available yet? Is there a Blum rep prowling this forum? I'm working on a design for a super modern kitchen. No pulls allowed. I need a bi-fold and pocket system that can be used without pulls. The HAWA concepta system looks good, but seems like its going to need some sort of pull to work properly.
Input?
Thanks,
-Michael
Blum Pocket Systems
4/17/20       #2: Blum Pocket Systems ...
I don't know anything about that particular Blum hardware, but I'm glad you shared it.
I despise the way we currently do pocket doors, and that might be a better solution.
4/17/20       #4: Blum Pocket Systems ...
Agreed Karl,
I've done several with KV hardware. Not too jenky, but not too great either. No soft-close, smooth and silent action this job requires. What system have you used in the past?
4/17/20       #5: Blum Pocket Systems ...
We've always done the KV with the rack and pinion rod. Most of what we do is inset, and it just won't hold a tolerance. People are really hard on pocket doors too and I always try to talk them out of it as it will eventually lead to a call back.
4/20/20       #6: Blum Pocket Systems ...
EJH Cabinets and Construction Member
Website: ejhcabinets.com
Michael the Hawa does require a pull in the center. We did a kitchen with Fingerpull and Blum touch to open. The way the Hawa mounted in the center there was no way for it to work with the Fingerpull. We ended up with the Handles that mount on the backs of the door and this worked great. The small vertical lines in the back of this picture. Tough to see from 20 feet but there when you need them. It has "Soft-close" But not sure this works all that well. We used the Hawa Concepta 25 tall. Overall the product did the job and looks great. I'll search for a better picture. Prob easier to email...
View higher quality, full size image (1414 X 1413)
4/20/20       #7: Blum Pocket Systems ...
EJH cabinets,
I think I am going to have to use a solution similar to what you did. This project calls for a flat black panel product, so it should be easier than glossy white to make minimal pulls disappear. How was the blum tipon mechanism used in your project? Appreciate you sharing!
