Subject: Re: SUN DAMAGE ON PRE-FINISHED CHERRY PLYWOOD
6/10/20
brant Member
I built some tradeshow cabinets out of pre-finished cherry plywood.
The client left them under a skylight with some books and junk on top for a month (stay at home orders kept them out of the office). As you can imagine the sun darkened the plywood everywhere except where the books were.
Is there anyway to even out the sun tan on these pieces?
6/10/20       #2: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
Dustin orth
Put them back in the sunlight, it will even the color out as close as you can get without stripping and refinishing. It might take a few weeks, hopefully you aren't packing these up for a show that quick.
6/11/20       #3: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
Stuart Douglas Member
In my experience, these will never come back to a usable state. You may be able to lessen the tone difference by exposing the sheet to additional time in the sun, but the prefinish, by its very nature is going to work against you, and It will NEVER look like it's original state. I know it sucks, but you will need to either refinish (50/50 at best) or remake those exposed pieces. Pretty sure this happens to every woodworker at least once (hopefully only once) in their career. At least it was your client and not you who did the deed.
6/11/20       #4: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
rescraft
I remember when I ordered a set of cherry shaker doors. When I picked them up and unwrapped the stacks, there were all sorts of areas where things were stacked, and the difference in color similar to the OP. When I talked to the door company owner, she gave me an attitude, saying "well I guess we'll have to just do something about that in the future." Sorry, no more business from me.
6/11/20       #5: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
Family Man
Very meticulous taping off of the darker areas with the same approximate amount of time in the sunlight followed by another week to even out the tape lines. In a few months you won't be able to tell. Most people do not have the patience for that though.
6/12/20       #6: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
Sadly, they will never look right. We have had large tables that had clamps going across them while building, and they shadowed overnight! At the very least, we put black plastic covers overnight. Veneer seems to respond to shadowing more than solid wood, but solid shadows also.
We have tried the sunlight remedy with no success.
We rarely to clear cherry finish, even our 'natural' cherry has a light stain on it. It helps a lot. It seems to block the UV rays.
6/12/20       #7: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
Have them take the cabinets outside for direct sunlight on sunny days. Might take a week of sunny days, but works faster than sitting in front of a window.
6/12/20       #8: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
brant Member
thanks all for the responses. The client is going to take the effected pieces and put then outside. Fortunately the pieces dont ship for another month.
6/14/20       #9: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
CGiles
I've been down this road a few times with cherry and mahogany. Sadly, nothing will correct these tops. They are toast. Refinishing, tried it. Setting it in the sun, the darkened part keeps darkening just like the lighter. Unless you can plane off about a thirty second of an inch, which of course, you can't do with a veneer top, its over.
These customers caused the damage with their negligence. Coming to you assuming you are at fault is B.S. If you can, remake the tops at a reduced rate that still covers your time. That is your solution. Best of luck with it, you'll get through it.
6/15/20       #10: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
rescraft
Add pinstriping around the lightened areas and have an artist paint in the company logo.
Consider it progressive graphics.
6/15/20       #11: SUN DAMAGE ON PRE-FINISHED CHERRY P ...
At this stage painting them is the only solution.
Thanks for pics. I will show them to all of my future cherry customers.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
