Subject: Re: Adding a tank to a non inverter screw compressor
7/21/20
Anton  Member
I recently purchased a non inverter screw compressor rated 7.5 hp with 60 gallon tank.
Air needs are sporadic with CNC operation and conventional paint spraying some days, with other days limited to nail gun usage and minor leakage.
Is it ill advised for me to connect a 120 gallon tank to the 60 gallon tank to reduce cycling considerably? The ELGI salesman see nothing wrong with it. We are a 5 person operation.
7/21/20       #2: Adding a tank to a non inverter scr ...
mick steele
Adding a storage tank would have an effect on compressor stop/starts. Question is what size tank makes most sense. There is probably some formulae that would give the information. A tank in a compressor system is used to dampen out the pressure fluctuation on the outlet of the compressor thus providing the users with more stable pressure throughout the system as a whole. Additional benefits are more precipitate dropout (water/oil) and increased air volume at periods of higher demand resulting in fewer cycles. The only downside I see is if a 120gall tank is too large recovery time for compressor may be an issue.
7/21/20       #4: Adding a tank to a non inverter scr ...
Anton Stayduhar  Member
Given that the screw compressors are designed, apparently, for 100% duty use, I would think the add-on size shouldn't weigh too heavily in the equation. It'll on/off less, and stay on longer to get back the 125psi. The new tank is 60 gallons; the old tank is 120 gallons.
7/21/20       #5: Adding a tank to a non inverter scr ...
mick steele
100% duty use does not mean capable of running 100% of the time. What is being referred to is a duty cycle and they are saying for every duty cycle it will meet the specifications of that duty cycle at 100%. So if the specification is 50cuft/min@90psi then every time the compressor kicks on it is delivering air at 90psiand50cuft/min. Within the compressor specs will be a rated number of duty cycles per 8 or 24hr period. In any case adding storage capacity generally helps rather than hurts.
7/21/20       #6: Adding a tank to a non inverter scr ...
In our compressor room we have two tanks.
The air comes out of the compressor(s) into the side of the "wet tank", out of the top of the wet tank to a filter, out of the filter into the drier, out of the drier into a polishing filter then into a dry tank and into the shop.
We had an auto drain on the dry tank but we took it off. Nothing ever came out of it. Once is a while we crack a valve to check but it is always dry.
If you think about it for a moment we have a large supply of dry air in the dry air tank. If your components and driers are set up for 50 CFM and you pull 60 you could pull wet air that the drier could not keep up with.
So if you want to increase your air quality and give yourself a cushion a tank is a good idea. If you want to save money on electricity or get away with a compressor that is too small the math will not work. A tank is expensive.
Good luck!
7/21/20       #7: Adding a tank to a non inverter scr ...
anton stayduhar
When I said 100% duty cycle, I did not infer or mean to imply the thing just stays on all day long. It stays on long enough to bring 180 sum total gallons of air back to 125 psi. Certainly, the compressor doesn't wait for the pressure to drop, for example, to 50 PSI to fire on.
Secondly, the 120 gallon tank is mine, and has been for 15 years. It's my old IR compressor tank, built for 175 psi, which I've drained multiple times a year since owning. I'll leave the IR head (which still runs like a tank) on the unit, simply unwiring it.
We rarely have need for heavy amounts of air more than 2-3 hours a day. Again, we're a small operation, and don't use air sanders (for example). I'm tired of the IR noise, and never had interest in putting it outside here in nasty upstate New York. I'm also looking forward to the savings in electricity. Yeah, I know it'll take umpteen years to make it pay for itself......but I also know I can't take it with me. :-)
7/22/20       #8: Adding a tank to a non inverter scr ...
Ryan
We have the same issue that you do with our screw that we don't use a lot of air all of the time. Screw compressors are meant to run all the time even if they are not pumping air all of the time. Because ours doesn't pump air enough to get the pump hot we were getting condensation in one of the pipes inside the compressor and it was starting to rust. I would run the smallest tank that you can run to keep the compressor pumping air as much as possible.
7/22/20       #9: Adding a tank to a non inverter scr ...
Anton  Member
Thanks, Ryan, for your comment. I had a couple of long conversaron with a thoroughly knowledgeable ELGI tech guy earlier today. He stated the larger 120 gallon tank that I've adjoined was a good idea (at least with Elgi) because they strongly frown on more than 6 on /off cycles per hour. That works for me.
    • Laguna Tools
    • Biesse America
    • Anver Corporation
    • WalzCraft
    • Machine Bid
    • Denray Machine
    • American Vision Cabinets
    • Salice America Inc.
