Subject: Re: Shop/workspace flooring solutions over rough concrete
1/22/19
matt
Good day folks,
Got a shop floor question for you. We have around 12K square feet of shop with concrete flooring that varies in it's quality. It was also painted before we acquired the building, it was painted with oil based enamel (not our choice, obviously not the best solution).
We'd prefer it to be more level and smooth. Some areas were floated well, and are sufficiently smooth, but a good 4,000 sf is much more coarse, not floated.
What are our best options here? We don't mind the oil based paint on the floor, it's easy to touch up and a lot cheaper than epoxy, but we really need to smooth out this rough stuff.
Would it be better to rent a concrete grinder and get good with it, or should we look into a flooring that would install over the top of the concrete---- something that will stand up to having an 8,000lb forklift on it.
1/22/19       #2: Shop/workspace flooring solutions o ...
Grind it smooth or lay a topcoat of skimcoat or resurfacer.
1/22/19       #3: Shop/workspace flooring solutions o ...
This is a tough question to come up with a great answer. I guess it all comes down to cost of the work, downtime on equipment and labour if you have to move or protect equipment in areas where the work takes place.
I would get some prices from others on both grinding, shot blasting/sand blasting and skim/top coating. I think in the end the cheapest option is to rent the equipment and do it your self. Concrete is not the type of material where you have to worry about making big gouges with grinding, unless you have some monster equipment. It is fairly
forgiving when it comes to grinding. If you are happy with paint, just go that route, it will be the cheapest by far.
1/22/19       #4: Shop/workspace flooring solutions o ...
matt
Thanks for the input guys, this is an area that I am just not familiar with.
We have a fairly significant shop rearrangement in the near future so your input here is helping me find the best solution.
We'll definitely need to skimcoat some areas, I just hope we don't have it flaking off later on if we drive the forklift over it.
1/22/19       #5: Shop/workspace flooring solutions o ...
Jim Herron
I would use a bonder in the skim coat like Laticrete, very similar to wood glue.
1/23/19       #6: Shop/workspace flooring solutions o ...
Stewart Member
If you do decide to grind, I would be super careful to cover any tooling in the area with plastic (or remove it altogether) as concrete dust and bearings don't mix well.
1/23/19       #7: Shop/workspace flooring solutions o ...
Chris Member
Check out the flooring forum on garage journal. There are like 130k posts there and a bunch of pro floor finishers and vendors. They should be able to give you some additional ideas
1/23/19       #9: Shop/workspace flooring solutions o ...
I have some experience in this area and the tools available locally to me to rent are toys. Grinding 4,000 feet would be too much.
My strategy would be to grind the paint off and scratch up the concrete, then put a bonding agent as suggested then use a leveler to put down a thin smooth coat.
There are companies that specialize in this. I would at least get a couple quotes. The worst thing that happens is you learn the proper technique then do it yourself. In my experience grinding 4,000 square feet would take days with rental machines. My instinct would be to hire it out. They have ride on machines that make quick work of it.
1/23/19       #10: Shop/workspace flooring solutions o ...
matt
That's helpful to know, Bill, thanks for sharing your experience here. I'll investigate and see who does that around here.
And you guys are absolutely right about the dust, we will cover the machinery with plastic--- that dust would wreak havoc on our machinery.
1/23/19       #11: Shop/workspace flooring solutions o ...
Alan F.
There was a new OSHA silica standard that came up a year ago. Be aware of it and maybe consider outsourcing grinding.
Our stone vendors used to ship tops 1/4" oversize based on our production shop drawings and grind in the field, they now template everything so there is no field grinding to avoid this issue.
A-
OSHA Regulations On Concrete Silica Dust
1/23/19       #12: Shop/workspace flooring solutions o ...
MarkB Member
I'd be another vote for sourcing this to a professional. The grinding is the simple part regardless of how long it takes. The hard part is know which thin surface coat is going to last (if any) given your specific conditions. Moisture, vapor barrier below or not, thickness of your existing slab, and then the elephant in the room will be the forklift.
I would want to have someone that can give me a fairly reasonable assessment of what I can expect from my investment in 2-5-10 years.
Making things stick to concrete is not easy and making thin things stick to concrete is an even harder task. Then you add in traffic, wear, deflection from the fork truck, and you may well wind up in a no guaranty situation but at least you'll know what your in for and you'll hopefully know youve got someone who has a pretty good idea of what your in for.
1/30/19       #13: Shop/workspace flooring solutions o ...
Derrek
If it has paint on it pretty much anything you donrequires it to be removed. There are commercial grinder and polisher that will bring it down smooth as can be. Lowe’s stores are ground and polished. If you are going to repaint with epoxy you can have it shot blasted, it’s a machine that has a bunch of small steal beads in it and takes paint off and a very small amount of surface concrete, leaves the surface a little tougher than grind and polish.
9/9/20       #14: Shop/workspace flooring solutions o ...
Dominic S Member
Website: https://concretepumpingsandiego.com/
Being a concrete pumper, I would suggest you go for commercial grinder and polisher. These will remove very little of the concrete.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
