Subject: Re: Customer relations
Customer relations
12/3/20
Nick Cook Member
Website: http://kootenaicabinets.com
A customer out of the blue decides she wants the shelves on this island as well as the sides in all solid wood. Here's her quote, "I understand that can happen. But we do need solid wood shelves. It will crack from any moisture and this will see heavy use. An exposed shelf cannot be protected with plastic like the inside of drawers. We have had an oak dining table that was veneer and it doesn't take long even with every precaution until it cracks. We will never buy a table that is not solid wood again." This came about because she was asking why the samples we provided for stain looked different on sold wood than on plywood. I told her that solid wood can stain differently than plywood. When she does finally decide on a color we'll make it stain evenly. Previously she had wanted us to rub through parts of it, to copy a bench she brought in that was old and had worn stain that was all over the spectrum as to dark and light. This is her design, the way the shelves attach to the posts etc. At know time did she tell me she wanted all solid wood. Here's my question, with this design is all solid wood, a good design in regards to the joinery? This is one of those jobs I should have not taken or had the customer provide drawings with dimensions on every aspect of the entire project, which is a kitchen remodel. Micro managed down to the size of the scratch on a distressed door.
View higher quality, full size image (720 X 960)
12/3/20       #2: Customer relations ...
Sounds like you are in the major hot place. Pitch forks, horns, forked tails,.. Yikes. Not sure what your solution would be if you didnt line out every detail ahead of time. Easy mis-step for any of us if your customer interaction and contract are not rock solid.
Pretty difficult to back step and move to solids at that point.
12/3/20       #3: Customer relations ...
Anon
I've been at this 30 years, so the response I give now is not what I would have given even 10 years ago. But I encourage you to at least consider what my experience has taught me.
You are in a no-win situation. This customer will not give you a positive review regardless of the solutions you provide, if that even matters to you. I assume the only reason any of us would entertain the idea of completely remaking this island is because we believe our integrity is on the line. It is not, especially in this circumstance.
My response would be, "There is not even the remotest expectation that we should have known you wanted this table made from all solid wood. It is such a rare practice in the field of woodworking that the idea of even discussing it as an option cannot be expected. Furthermore, by taking such an active role in the design of the piece (down to the size of the scratches in the distressing) you have assumed far more responsibility than would typically be expected. It was incumbent upon you to tell us specifically that you wanted this made from solid wood. Now, here are your options. First, we will not remake this piece from solid wood at no charge to you because we did nothing wrong. Second, if we do agree to make this piece from solid wood, our original price to you is no longer valid and we reserve the right to re-bid it. You will be responsible for the full price if we choose to re-build it. And finally, we reserve the right to keep the table and respectfully decline to make a new one if we so choose, and wish you good luck with whomever you choose to build your project.
12/3/20       #4: Customer relations ...
Anon
I should have been clearer, options 2 and 3 do not result in the customer paying you a dime for the 1st table. You are keeping the 1st table and deciding for yourself whether to build a new one at a fair price considering the new specification, or you are keeping the 1st table and declining the job altogether.
12/3/20       #5: Customer relations ...
Alan F.
Shelves usually don't get the same wear as a table. A table gets hot and cold, spills, kids, and life in general.
If the oak veneer table is cracking then maybe there are wide changes in humidity or temperature, or if it was custom made, maybe it was poorly made or finished. It is also possible that they put very hot plates or platters right on the veneer.
If the issue is temperature and humidity solid wood will be worse.
The sides are protected by the overhangs
Explain to the customer that its difficult to change now but that they can protect the wood by using a more durable finish.
There are plenty of coatings that will be plenty durable.
Did you do shop drawings or label your samples like wood edge of shelf and veneer surface of shelf?
I think the solution is a proper finish if the issue isn't the indoor temperature and humidity. You need to understand why the oak table is failing to address the problem.
A-
12/4/20       #6: Customer relations ...
D Brown
Maybe you could figure out how to cover the open shelves with a wood overlay or a shelf on the shelf ? Communication is key, best wishes.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
