Subject: Re: fastening wood top molding
4/8/21
Jonathan Mahnken
Best all around method for applying wood top molding without nailing?
4/8/21       #2: fastening wood top molding ...
packing tape and glue?
4/8/21       #3: fastening wood top molding ...
Leo G
Or use 23 ga headless pins and glue. Pretty invisible for the most part, especially in stained wood. In painted wood you can use a putty crayon to fill the holes. Only use enough pins to hold the molding on long enough for the glue to set.
4/9/21       #4: fastening wood top molding ...
Does wood top molding mean crown molding?
4/9/21       #5: fastening wood top molding ...
I have used smallest Dominoes putting a piece of paper under the fence to leave a few thousandths to plane/sand after glue up on mouldings that have the section to accept a 5mm mortise.
4/9/21       #6: fastening wood top molding ...
pat s gilbert
Something like this is useful if the cabinets don't go to the ceiling
4/9/21       #7: fastening wood top molding ...
daniel
P2-10 from fastcaps
4/9/21       #8: fastening wood top molding ...
pat s gilbert
crown molding with a step in it
4/9/21       #9: fastening wood top molding ...
Jonathan Mahnken
I meant a wood counter top edge molding. on a top that is already in place. I dont think packing tape will cut it. and I dont want to face nail in white paint. Even with 23 ga pins. Everything is prefinished. back in thee good ol days we nailed it on and let the painters do the rest. now we prefinish.
4/9/21       #10: fastening wood top molding ...
Leo G
Ahhh...
Glue and tape. Make your moldings straight and true and it shouldn't be much of an issue. Maybe a biscuit for alignment here and there.
I use a lot of 3M 401+ tape, it's green and has a pretty good stretch to it. Makes a good clamp, sticks well an will come off without damaging the paint as long as it's properly applied. Not latex, it'll rip that stuff right off.
4/9/21       #11: fastening wood top molding ...
TonyF
Jonathan Mahnken:
Is the top already in place with a finished square edge? If that is the case you may need some sort of spline to hold the new edge in place and to provide a place for glue.
As Leo says, straight molding always helps. I have a number of 3-screw edging clamps, which with the appropriate caul material, is what I would use for a prefinished edge molding application in the field.
The only way these would not work would be if the top had insufficient overhang to accommodate the clamp on the bottom of the countertop. These clamps would make for a very solid after-the-fact edge application.
Hope this helps.
TonyF
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
