Subject: Re: Hingeing a triangular door
8/6/21
Drew Z Member
Hi all,
Anybody have experience hingeing an inset, triangular cabinet door?
I need to hinge doors that are 45 deg triangles. The hinges are on the tall side of the triangle. I am beveling the hypotenuse's back edge at 45 deg as well to prevent binding in the top corner.
I know a butt hinge would work but need a cup hinge per the design for the project. I typically use 95 degree Blum hinges for everything and I know those won't work/will still cause a binding issue at the top corner. I need a hinge that has a motion that mimics a butt hinge and pivots around the front face of the door, essentially, or at least opens in a way that clears the face frame as it opens.
Anybody ever successfully used a 155 deg Blum for a similar application? I don't have any on hand to mock up the situation and thought I'd ask.
Thanks everyone.
8/7/21       #2: Hingeing a triangular door ...
Edi Silva  Member
Website: silvawoodworking.com
Salice hinge will work, don't know the number but we had the same situation and the 155 deg Salice did the trick. Maybe Dennis can help you with the right number.
8/8/21       #3: Hingeing a triangular door ...
pat gilbert
Is this what you are trying to do ;^)
Triangular door
8/9/21       #4: Hingeing a triangular door ...
duster
I had a similar problem with the arch top doors on this piece. I finally got it to work with Blum 155 degree zero protrusion hinges.
View higher quality, full size image (652 X 304)
8/10/21       #5: Hingeing a triangular door ...
Drew Z Member
Thanks guys -- I'll try out the 155 zero projection hinges.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
