Subject: Re: Sharp MW drawer and electric cord run
9/12/21
Gene Davis
This is gonna be frameless, and the cab is in an island with 12" deep cabs backing to what you see.
A careful read of the dimensions, tells me there is a space of 7/16" between the body of the unit and the side of the cabinet. I want to run the power cord DOWN that side near the rear, through the void behind the lower drawers, through the deck, where we can plug it to a floor outlet in the 4" toekick space.
If you have build these in frameless, and with the appliance on hand, is this a way to run the power?
We don't want to go into the cabinet behind.
View higher quality, full size image (449 X 499)
9/13/21       #2: Sharp MW drawer and electric cord r ...
Mark B
Looks like all the various drawings your building a new house? Why not have your electrical sub advise you. Providing a chase to power an appliance is pretty rudimentary if your a cabinet shop. Doesnt require much consideration.
9/13/21       #3: Sharp MW drawer and electric cord r ...
Gene Davis
I'm doing the eCabinets models in order to generate the CNC files for cutting the cabs. The electrical sub has been instructed on drawings to wire to a top-of-floor mounted recep in a location marked by the kitchen installer. That is the extent of the sub's powering of this appliance.
I've done a dozen of these Sharps but always with the cabinet backing to a wall. Now we have an island situation.
I'm told but have not witnessed that the power cord with plug end is 3 feet long. If that can be verified, and the wire itself will fit into a 7/16" gap, we're good.
9/13/21       #4: Sharp MW drawer and electric cord r ...
Mark B
If you've done a dozen of these exact units how can you, or someone in, or associated with, your company, not know what will work and what will not?
That simply does_not_compute.
9/13/21       #5: Sharp MW drawer and electric cord r ...
mike
not as good a place for helpful answers like it was years ago. sorry Gene
9/13/21       #6: Sharp MW drawer and electric cord r ...
Mark B
Its still a phenomenal place for answers for those in business but a bunch of questions feeling your way through a cabinet build (12 identical units in the past) is a bit of a stretch. I mean come on man? We are asking about routing and "plugging in" a cord" Thats a condition directly routed to your electrician.. is the receptacle code and accessible? is the receptacle in the location planned even allowed" Will the appliance need to be direct wired instead? These are not "cabinet making" questions.. You cant burry a receptacle/device... period. You would be unwise to create a "pinch point" for a corded appliance regardless of a "7/16" cord diameter"..
You dont build a spice n' oils pull out 10 years ago with side mount slides laying on the flat and then suddenly realize you ran ONE on the vertical and a woeful second on the flat up top as a guide.
It make no sense.
9/13/21       #7: Sharp MW drawer and electric cord r ...
Mark B
Add in cross posting?... and.. uh.. kerplunk.
9/13/21       #8: Sharp MW drawer and electric cord r ...
mike
i'll say it again . really hard to get positive answers that can help you Gene.
9/13/21       #9: Sharp MW drawer and electric cord r ...
Mark B
There are not too many positive answers to be gleaned from routing factory wired MW plug. If your truly confined to the diameter of the cord your likely in a pinch point at the strain relief coming out of of the back of the appliance (unless you know based on your last 12 identical units that the cord comes out of the top or bottom or a stamped up/down relief in the rear of the unit).
Sorry to sound like douche but every photo and every question is from the same render. Maybe its a 52 unit condo complex but again, cross posting, and a spice pull out with two slides on the flat is kind of odd for anyone who's had a side mount slide in their hand for more than a nano-second. You'd simply never draw that.. EVER..
Is what it is.. dont be a whiney babie
9/13/21       #10: Sharp MW drawer and electric cord r ...
Jon Member
I've also done a dozen or more of those, but most were FF cabinets. If I remember correctly, there would be room for a surface mount box in either the upper right, or upper left of the opening. I think those don't use a plug, and are wired directly into a junction box, so maybe you could use a box for a 2" wall.
9/13/21       #11: Sharp MW drawer and electric cord r ...
Jon Member
Another thought would be put the box behind the drawer in the cabinet to the right, or behind the drawer below the unit.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
