Subject: Re: piano hinge vs ?
piano hinge vs ?
12/10/21
Tony
Guys-I have a situation where I need to hinge 2 doors to make a bifold set that folds back together. My first thought is a piano hinge, which will work, but I'm sure I've seen some kind of edge mount leaf-type hinge that would also work and not show. I looked at barrell hinges but I don't think they will allow the doors to fold together like I need. Can't remember what they are called. Any help would be appreciated. Thanks
12/10/21       #2: piano hinge vs ? ...
SOSS hinges should work.
12/10/21       #3: piano hinge vs ? ...
Website: http://www.acornwoodowrks.com
Soss is being replaced by Tectus hinges and similar by Sugatsune. They are better engineered and have 3 way adjustability. Look on Gary Katz's website for an article about using them.
https://www.thisiscarpentry.com/2013/10/04/tectus-hinges/
12/10/21       #4: piano hinge vs ? ...
Tony
Thanks for the help. I did find the Soss hinges.
12/11/21       #5: piano hinge vs ? ...
james e mcgrew  Member
May be competition yet Soss has not been replaced
https://www.soss.com/
12/11/21       #6: piano hinge vs ? ...
Jim
Slice pie cut concealed hinge
Blum has similar
12/11/21       #7: piano hinge vs ? ...
duster
I've done this a lot with non mortise hinges for bi-folding pocket doors for TV cabinets. I mount them on the back sides of the doors with a 1/16" reveal between them. The doors will fold back completely with only the barrel showing.
View higher quality, full size image (1100 X 744)
View higher quality, full size image (1100 X 733)
12/13/21       #8: piano hinge vs ? ...
Jim
Sorry I misunderstood the application
I'd use Hafele Aximat Institutional 270
12/30/21       #9: piano hinge vs ? ...
Scott Markwood
Website: http://www.hafele.com/us
I second the suggestion of the Häfele Aximat bifold hinge, though I would go with the bifold version, article number 343.91.600 found in the 2022 version of the "Complete Häfele Catalog" on page 9.7. This hinge will gives you quick vertical adjustment of the door and horizontal adjustment of the gap. Scott
View higher quality, full size image (868 X 772)
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
