Subject: Re: Stiles and rails
Stiles and rails
3/14/22
Herb Member
I have a customer asking for 96” tall by 16” wide cabinet door with 1” stiles and rails. Just wondering if anyone has ever done that. Thx
3/14/22       #2: Stiles and rails ...
Yes, I assure you, it has been done before. And successfully. The sky did not fall, the gates of hell did not open. Life went on.
3/14/22       #3: Stiles and rails ...
Herb Member
Thx David. I’m. New here so I don’t know the protocols but I appreciate you responding.
3/14/22       #5: Stiles and rails ...
Roy Cameron
Make it out of 1 piece mdf 7/8 thick, melamine back.
3/14/22       #6: Stiles and rails ...
gary
1" wide or 1" thick? Paint or stain grade?
Not sure what the sky or gates of hell have to do with it.
3/14/22       #7: Stiles and rails ...
Herb Member
Sorry 1” wide.
3/15/22       #8: Stiles and rails ...
Edi Silva
what type of hinge?
3/15/22       #9: Stiles and rails ...
gary
If this is to be standard five piece door construction with solid wood door panels the sky may fall on it.
3/15/22       #10: Stiles and rails ...
Herb Member
Yes standard shaker flat panel door, one 1” wide cross rail in the middle. Haven’t even thought about hinges yet. Standard hinge won’t fit. I’m still stuck on how it could hold together. Just thought I’d post here to see if anyone may have done this. Thx for the responses.
3/15/22       #11: Stiles and rails ...
gary
Does it is gets painted? If so, machining it out of mdf would be the way to go. Cup hinges still may not work because the panel area would be too thin. Maybe there is a shallow cup hinge? Going up to 1 1/8" or 1 1/4" thick would allow the use of a standard cup hinge.
3/15/22       #12: Stiles and rails ...
Ed Austin
Glue 3/8" battens to a 5/8" panel , then regular 35mm hinge will work , maybe get a thick door hinge,
3/15/22       #13: Stiles and rails ...
Herb Member
Thx Gary
Yes it’s paint grade.
I think machining it might be the way.
3/15/22       #14: Stiles and rails ...
Herb Member
Ed I just read yours that is an option as well. Thx
3/15/22       #15: Stiles and rails ...
I made the panels from 3/4" mdf, then wrapped them in solid. Mitred the corners for the wrap. That job, the frame was 3/4" wide, and 1" thick. Creating a square profile door.
It was a hassle, and time consuming. We cut a rabbet into the front edge of all of our shelves, then the facing has a groove in it to slip over the tongue that the rabbet creates. Basically used the same joinery on the doors we made. No nails, just clamp everything together. Knocked the back flat with the lipping planer, then pitched them all through the widebelt face up to just make that all happy.
That was just a few cabinets in a kitchen. Mix of paint and riftsawn white oak. Maybe 20-25 fronts, so not a ton.
We've got another job coming up, same theory, but the frame will be 1-1/2" wide. I think we're going to do that in a similar fashion. That's a whole kitchen also in rift white oak. I'm not real excited about that.
If it were all paint, and I cleared it with the customer, I'd shallow up the frame to panel offset, then cut them all on the cnc. I'm not a huge fan of machined mdf doors, but this would be a good way to not have to charge an arm and a leg for fronts. Or deal with the potential issues of having a non-stardard thickness door/drawer front.
View higher quality, full size image (2548 X 1911)
3/15/22       #16: Stiles and rails ...
I don't see you getting any joinery in that middle rail if you use 3/8" deep dados.
3/15/22       #17: Stiles and rails ...
Herb Member
Thanks for all the responses.
Lots of good ideas.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
