Subject: Re: Corner cabinets
Corner cabinets
3/22/22
Jeff
Ok the first thing I will say is I hate corner cabinets. The second thing I will say is I will never design a job with them in it.
Unfortunately I don’t always have the say. So I ask what adhesive are you using to apply the edge tape, and how are you squaring off the corner to install the edge tape.
I do not have any type of hand held edgebander as I do very little of this:
My process is to cut the L shaped piece on the cnc, and use water based contact cement. The process is very slow and tedious.
What is everyone else doing. I know there are a ton of smart people on here.
3/22/22       #2: Corner cabinets ...
What are you really complaining about. The bottom of the cabinet and the rotating shelves? Just the shelves? If shelves, spec metal shelves and that solves that issue. If the bottom bothers you, use solid wood banding and pin that on the internal L cutout. Corner cabinets are not the most difficult cabinet you will ever make.
3/22/22       #3: Corner cabinets ...
Chris
The odd time we have to do an L-shaped base corner with bi-fold doors( we always try for blind corner w/ lemans pullout) we cut the parts on cnc as well. We don’t square the corner, we just use 1 pc of banding and wrap it around the corner. Depending on the thickness sometimes we will need to use a heat gun to get the banding fully seated in the radius.
3/23/22       #4: Corner cabinets ...
Jeff
Rich, you are probably right, it is probably only a mole hill that I am marking a mountain out of. It just seems very time consuming to me to cut the corner square and hand apply the edge banding. It is prefinished plywood and prefinished wood edging .I will just get er done!
3/23/22       #5: Corner cabinets ...
Gene Davis
Consider this, and always remember, it's a hidden element. You can only see it when doors are open, and who's really inspecting?
Two pieces tape, taped to where the corner round from the router bit begins. Then some spackle or filler, quick-dry, to smooth up that tiny area, then touch up paint to match things. If the banding is woodgrained, just use a color that comes close enough so the little corner looks OK.
Less work that trying to wrap the inside curve with banding. Less work than cutting it square. I know because I have done it with razor sharp cabinetmaker chisels. To do that I had to bench the parts to get the piece in place for the right angle to the corner.
I just sent a job to the CNC shop, and it included two such, and the shop will do it this paint-the-corner way.
3/23/22       #6: Corner cabinets ...
Jim Herron
I build those in two pieces.
RH side has two ends, bottom deck, 11 inch top stretcher and a back.
LH side has one end, 8 3/4" bottom deck, 5 1/2" top stretcher, and back
Run all through the bander, assemble, and pocket screw the deck and stretchers together at the jobsite, forming the 90 degree corner cab
Install L door with 165 hinges, the right door to the left door with pie cut hinge, install Susan, and done
Also make transport much easier
3/24/22       #7: Corner cabinets ...
Tipper Member
I build mostly face frame cabinets. Angled corner cabinets are much more time consuming than L shaped corner cabs. Especially comparing face framed to frameless. If I were doing an L shaped frameless corner cab, and if my CNC didn’t have the proper bits to make the corner almost square, what I would do is cut the bottom out on the table saw. It only takes a few minutes to mark your lines and run it through.
