Subject: Re: Medex "crowning" after being cut.
6/9/22
Adam Clark Member
I have 3/4" and 3/8" Medex that I am using to build paint grade cabinets (open, full height adj. shelf/rod closet cases). I am using Medex because I am looking for a superior MDF product that holds screws, machines, finishes, etc. nicely. When cutting the Medex, the pieces have begun to "crown." The panels I have cut so far are around 19", so the crown is only 1/16" to 3/32". However, smaller pieces (around 9") are pretty bad. See photos. Has anyone had experience with this? Are there other MDF products I should use instead?
View higher quality, full size image (2167 X 1625)
View higher quality, full size image (2098 X 1573)
View higher quality, full size image (2136 X 1602)
6/9/22       #2: Medex "crowning" after be ...
Leo G
Yes, I've had it happen. I now treat it like I would real wood. Cut oversize then straighten and cut to actual size.
Wait til you find out how much it changes size during the year.
6/10/22       #3: Medex "crowning" after be ...
Adam Clark Member
Have you tried Pluma Ply? Advantages, drawbacks?
6/10/22       #4: Medex "crowning" after be ...
Leo G
Never heard of it. Usually I use Plum Creek or Weyerhaeuser for double refined MDF.
MEDEX is a water resistant MDF, best used for kitchens and bathrooms where the double refined might not fare as well.
6/11/22       #5: Medex "crowning" after be ...
Edi Silva  Member
Website: silvawoodworking.com
I've been using Pluma Ply for quite some time now for all our Paint Grade cabinets,
Advantages:
*Lighter than MDF
*Take the screws way better than MDF
Drawbacks:
*Very expensive right now (We use Garnica from Spain)
We use 3/8'' Medex only for our paint grade doors.
6/13/22       #6: Medex "crowning" after be ...
Bruce H
I cut many of my parts oversize and cut back to finished size where it is critical. Lately we have had issue where MDF is changing dimension after it has been cut and painted (both sides and edges)
6/14/22       #7: Medex "crowning" after be ...
Adam Clark Member
Here's two pieces stacked face to face showing how cupped they are.
View higher quality, full size image (2233 X 1256)
6/14/22       #8: Medex "crowning" after be ...
Leo G
Wow that's bad. It should never be like that. A little curve when cutting is understandable. But to warp like that is totally unacceptable.
6/14/22       #9: Medex "crowning" after be ...
Bruce H
First off you are storing them vertically. Second, the face sheet is exposed to the air differently than the back of the sheet and the rest of the sheets. They are going to warp in that storage situation. I store them flat with a cover sheet on the bottom and a piece of cardboard on the top.
6/14/22       #10: Medex "crowning" after be ...
Adam Clark Member
The storage is quite temporary as they are in the picture. They only stay that way for a day or so. The curve that you see has been the same since I acquired the sheets. A bit worse after cutting. When I purchased them they had been stored exactly as you describe.
6/14/22       #11: Medex "crowning" after be ...
Bruce H
We make an effort not to use the top sheet until it has been acclimated to my shop. The longer we have it in storage the less of a moisture imbalance issue there is. I wouldn't store sheets in a vertical situation even over night. It will lead to problems. If you took that warped sheet and laid it where air circulates to both sides it will come back flat at some point. Your warp is caused because the face is drier than the back.
6/14/22       #12: Medex "crowning" after be ...
Adam Clark Member
Thanks for the advice. I'll store them flat for a few days as described prior to installation and see what happens.
6/14/22       #13: Medex "crowning" after be ...
door shop guy
I never met a piece of Medex that i got along with.
