Subject: Re: How would you groove these toe boards?
1/9/23
Matt Member
We're looking to lean up/improve the way we groove our toe kick boards. We use leg levelers, so our toe kick is 3/4" thick material with two grooves on the back. The middle is just a 1/8" kerf cut for the toe clip to be hammered into, and the top rabbet is a notch to avoid hitting the leg socket's top flange.
I'm trying to figure out how to cut both grooves in one pass. We're going to set up a single tablesaw or router table with a power feeder to do nothing but groove toe kicks. We have several major projects about to hit and we're going to be grooving a few hundred linear feet per day of this.
My three options seem to be:
1) Router table and power feeder using a box joint bit stacked just to cut these two notches, or perhaps a custom router bit.
2) Tablesaw with power feeder and use a dado stack, except with spacers between the two grooves. I'm actually skeptical that our old Unisaw has an arbor long enough for this.
3) Williams and Hussey benchtop moulder with a custom blade. The downside here being HSS knives. We groove a LOT of melamine here and those HSS knives are going to take a beating. The cut doesn't have to be particularly pretty since it's never seen but I can't imagine HSS not being wrecked after a few thousand feet. A carbide saw blade will go for most of a year without needing replaced.
Either way, the goal is to cut these the exact same with presicely 0 machine setup other than safety checks. Any suggestions?
View higher quality, full size image (2006 X 573)
1/9/23       #2: How would you groove these toe boar ...
Thomas Gardiner
With the spacing of nominally 2" for the two grooves I don't see you being able to fit this on a table saw arbor nor do I think you will be successful with a router bit stack.
This is a shaper job.
1/9/23       #3: How would you groove these toe boar ...
Bruce H
I don't think there is enough horse power in a router to make it efficient over the long run. I'd set up a table saw with a feeder for the spline grove and a shaper with a feeder for the bottom rebate. It might be possible to set up a single machine but the effort to do so would far exceed the saw and shaper combination.
If you really want a single machine you could make an arbor that has a shaper cutter and a saw blade mounted on it, that on a set of pillow blocks. Need a pulley, belt and motor to power it. Mount the whole thing and the feeder on a piece of plywood, add some legs.
I used leg levelers for twenty years but finally gave them up. There are faster, easier and simpler ways of setting cabinets on un-even floors. That means I am no longer trying to groove and rebate toe kick parts.
1/9/23       #4: How would you groove these toe boar ...
You can get carbide knives made for a Hussy, The carbide is brazed to knife stock. We use a similar knife on our Arch moulder.
This site has them.
Carbide knives
1/9/23       #5: How would you groove these toe boar ...
dr
change to different legs so you don't need the top dado.
1/9/23       #6: How would you groove these toe boar ...
I'd stack tooling on a shaper. Run it on edge, and flat against a continuous fence with just the tooling projecting from the fence face.
1/9/23       #7: How would you groove these toe boar ...
Dustin Orth  Member
My thought would be a simple 4 head molder, you would be able to get exact results, repeatability. No problem on the lineal footage either. Carbide tooling for this seems to be a must. Small investment for the speed of getting it done.
1/10/23       #8: How would you groove these toe boar ...
Your set up would be based on ft per week in my opinion. What kind of quantities are you cutting now? Sawing would be cut at twice the speed of a router. If you are looking at hundreds of feet per week, then run it through your molder.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
