Subject: Re: Glue set time
Glue set time
5/14/23
Dror Lev-Har
Good day
I started to assemble cabinets with dowels and case clamp. The average cabinet assembly take me about 10 min. Is that enough time for the prier cabinet in the clamp for the glue to set? Please advice.
5/14/23       #2: Glue set time ...
Probably not. Especially without you telling us which glue you are using.
5/15/23       #3: Glue set time ...
Rich  Member
I would think more than enough time, are you fastening your back while the case is in the clamp?
5/16/23       #4: Glue set time ...
I think it is enough time. If your time is compressed, you can use a few Sen clamp fasteners (Spot Nails makes a similar fastener) to allow you to pull if from the clamp almost immediately.
You can always test. Clamp it for a period of time and try to take it apart.
Do that in both high and low humidity for your benchmarks.
If you are using glue on one or both sides I would get in a florescent dyed batch oof glue and bandsaw the dowel joint in half and use a black light to see how the glue traveled up the dowel, or not.
Good Luck!
5/16/23       #7: Glue set time ...
Dror Lev-Har
Thank you for your response I feel better now. Yes I do fasten the back wile in the clamp, I also apply glue in the groove for the back.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
