Subject: Re: NotifyOnlyPost
Biesse edgebander alarm
6/29/17
Bob Member
I have alarm on Biesse edgebander :
Alarm #2 safety switch on.
Any idea what is that meaning?
View higher quality, full size image (3629 X 2039)
7/5/18       #2: Biesse edgebander alarm ...
Yopie
Hi Bob,
I have the same problem with my jade edge bander and though you have solved the problem/error.
If so, please help to share the solution.
Beside, my machine also show errors 36 and 80.
Thank you very much,
Yopie
7/5/18       #3: Biesse edgebander alarm ...
Bob Member
Hi Yopie
It was magnetic switch ( relay) easy to fix just replace cost around $80
7/5/18       #4: Biesse edgebander alarm ...
Yopie Member
Hi Bob,
Thanks for the great and valuable information.
I will try to find out which magnetic switch need to be replaced. Do hope I find it.
BR, Yopie
9/4/23       #12: NotifyOnlyPost ...
bes Member
Hello, I have a problem with Biesse Akron 440, the problem is that it says alarm 12 magnetothermic switch, what can I do?
9/19/23       #13: Biesse edgebander alarm ...
William Hobbs
I have the same problem on a Biesse akron 435. Would love to know how to fix it.
4/23/24       #17: Biesse edgebander alarm ...
Yeshi Member
My edgebading machine shows “ cutter/ blades inverter” alarm and I could not fix it . Can you help me plz
5/18/26       #22: Biesse edgebander alarm ...
ahmed ezzet Member
problem reason from selector at operating screen for tooling as shown in wiring diagram or safety switches for cabin
5/18/26       #23: Biesse edgebander alarm ...
William Hobbs
That is usually a circuit breaker which has cut out
Easy fix. Open bottom front locker and check that all the circuit breakers are on.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
