Subject: Re: I need advice Mozaik vs Fusion 360
1/9/24
cooleh88 Member
My boss has tasked me to look into Fusion 360 to replace Mozaik because his son who runs a metal shop says that Fusion 360 is the best. Our current process for jobs is this; we draw the job in Autocad for architectural approvals, and then it is drawn in Mozaik for assembly sheets and to optimize the job. My boss is thinking that we can go to one program instead of two by going to Fusion 360. What are everyone's thoughts on this?
1/10/24       #4: I need advice Mozaik vs Fusion 360 ...
Tim Member
We struggle with the same workflow issue. Autocad for the shop drawings and then it all gets done again in Mozaik, or at least the parts of the job that are CNC’d.
We do custom cabinets and millwork.
I’ve used F360 a bit. It’s nice software, but seems to be more useful for custom parts. I think tool pathing would be tedious work for a job with hundreds of cabinet parts.
I’m pretty committed to Mozaik, less so to Autocad. I’ve considered switching to Sketchup Layout for shop drawings. Since Mozaik exports to Sketchup already. Check out some architectural drawing sets done this way. They look really great, and everything is 3d modeled which helps the shop floor out immensely when reviewing drawings.
I also know many shops simply submit the drawings (elevations/plans) generated by Mozaik/Cabinet Vision for approval. That could be a simple solution. It’s not a great option for us, but might work for you.
1/12/24       #5: I need advice Mozaik vs Fusion 360 ...
Quicktrim
Why are you drawing jobs twice ? I get all of my submittal drawings right from mozaik multi print . Are you not taking advantage of all the features in multi print ?
For custom work we export the cabs from mozaik to sketch up , draw the custom items and turn off to layout for final submittal drawings of there is too much non cabinet stuff.
1/12/24       #6: I need advice Mozaik vs Fusion 360 ...
The MW Studio Sponsor - The Millwork Studio
Website: themillworkstudio.com
Switching things up from Mozaik to Fusion 360 sounds like a cool idea! Fusion 360 is pretty versatile, handling both design and manufacturing stuff all in one. It could be a game-changer for streamlining your process.
Just a heads up, though – there might be a bit of a learning curve, especially if the team is used to Mozaik. Training might be key to make sure everyone's on board without too many hiccups. Considering you draw for architectural approvals in AutoCAD, make sure Fusion 360 plays nice with those needs.
Since the boss's son in the metal shop gives it a thumbs-up, it's worth a deeper chat with him to get the lowdown on how well Fusion 360 fits with woodworking mojo.
Maybe kick things off with a trial project in Fusion 360 to see how it vibes with your workflow. Have you dipped your toes into Fusion 360 yet, or is it still in the brainstorming phase?
1/14/24       #7: I need advice Mozaik vs Fusion 360 ...
Dave Edgerton  Member
Fusion 360 has no place in a woodworking shop. Its the wrong application for that software. If you do nesting then do it all in mozaik. Write scripts for autocad sop you dont have to reinvent the wheel or dumb down the shop drawings a bit. My 2 cents.
1/15/24       #8: I need advice Mozaik vs Fusion 360 ...
Stephen Williams Sponsor - Parts Cutter CNC
Website: http://www.partscuttercnc.com
Agree with Dave,
Do your cabinet layout in Mozaik and then export it as a DXF. Use the Overkill Command. You can then make it pretty.
The guy in the metal shop is making parts you are making cabinets, different world.
1/23/24       #9: I need advice Mozaik vs Fusion 360 ...
BH Davis  Member
I've done a lot in Fusion 360 for 3D printing and it is great for that. However I've always felt that, even though the capability is there, it would be cumbersome to use for cabinet work.
    • Western Dovetail
      Custom Made Dovetail Drawers
    • TradeJobPlacement.com
    • RT Machine Co.
